[Documentation Release] ESP31_RTOS_SDK_API Reference
Faye
Postby Faye » Mon Dec 21, 2015 7:36 am
Welcome to use ESP31. Here is the ESP31_RTOS_SDK_API Reference.
Click to download.
Enjoy !
Re: [Documentation Release] ESP32_RTOS_SDK_API Reference
Postby rudi ;-) » Fri Mar 04, 2016 4:11 am
hi guys
Docu update at Github, ESP32_RTOS_SDK V2.0.0
here comes the ESP32_RTOS_SDK_API Reference V2.0.0
-> PDF Docu
-> HTML sites
Enjoy!
ad@sysenco.net
Postby ad@sysenco.net » Wed Apr 27, 2016 4:46 pm
Hello.
Is there any API document that describes how the Bluetooth onboard can be used? I searched the few documents that I came across but am unable to locate specifically Bluetooth API.
WiFive
Postby WiFive » Thu Apr 28, 2016 12:39 am
Hello.
No there has not be a release of source code or documents pertaining to bluetooth. Official product launch isn't until end of June.
Postby rudi ;-) » Sat Jul 02, 2016 3:08 pm
Hello.
no - there are many infos about this - but only with NDA -WiFive - have you know about this possible way that we can get more infos and SDK and Tools with NDA? i am not.
Re: [Documentation Release] ESP32_RTOS_SDK_API Reference 3.0.0
Postby rudi ;-) » Sat Jul 23, 2016 9:46 am
hi guys
on pending ESP32_RTOS_SDK v3.0.0-16-07-23 release branch
there are new API Document v 3.0.0 too
read in
be sure you allways load from original place the right version to the right SDK release.
you see this in the "tree" of the version number
kolban
Postby kolban » Sat Sep 24, 2016 3:26 am
I'm not sure these documents are for the released ESP32 ...
As far as I can see, these links point to a Github project located here:
https://github.com/espressif/ESP31_RTOS_SDK
If we visit that page and then look at the description at the top of the page, we read:
ESP31B SDK on FreeRTOS. For ESP32 please see http://github.com/espressif/esp-idf
It is almost as though these docs were for the the early prototype boards (ESP31) and we are now being pointed to the "final" ESP32 where the ESP32 SDK is now called "ESP-IDF". If that's the case, the documents in these links (pointing to ESP31_RTOS_SDK) may not longer be truly relevant.
Angus
Re: [Documentation Release] ESP31_RTOS_SDK_API Reference
Postby Angus » Mon Oct 03, 2016 11:41 pm
Hi Kolban,
Thanks, this is correct. I've renamed the thread to reflect this.
For ESP32, the API header files in esp-idf contain doxygen-style comment documentation. We're curently discussing how to host these in a formatted version.
Angus
