ESP 32 with mems MIC SPW2430
Manveen
Postby Manveen » Thu Sep 06, 2018 8:27 am
Hi all,
I am trying to create project using ESP 32 with arduino IDE which turns on when a snap is detected.
I will be using using spw2430 mems mic
datasheet here :https://www.knowles.com/docs/default-so ... hr5h-b.pdf
Right now I using the Adafruit SPW2430 mems mic breakout board for testing purpose
product site here :https://www.adafruit.com/product/2716
The problem I am facing is whenever i snap my fingers or clap my hand the output voltage goes up (as expected) BUT it takes a 4-5 seconds to come back to normal reading .
Ideally it should not take that much amount of time to come back to normal reading. It should take 10 ms to come back to normal readings.
I am polling every 500 microseconds and the attenuation of the esp has been set to 0 db so that the REf voltage scale is in 0 - 1V.
this similar problem is happening with arduino uno (with same set of test conditions) .
The input of adc is connected to the DC pin of the Breakout Board.
(Which does NOT have any capacitor in between the o/p of mic and I/p of adc.)
Here is the code I am using
#include<esp32-hal-adc.h>
#define ANALOG_PIN 4
void setup()
  pinMode(ANALOG_PIN,INPUT);
   * typedef enum
    ADC_0db,      // 0 to 1 v
    ADC_2_5db,  // 0 to 1.27 v
    ADC_6db,     // 0 to 1.75 v
    ADC_11db     // 0 to 3.3 v
   } adc_attenuation_t; // changes Ref Voltage Scale
  analogSetPinAttenuation(ANALOG_PIN,ADC_0db); // Set the attenuation for particular pin currently 0-1 v
void loop()
  int raw_value = 0; // to store raw value of mic
  raw_value = analogRead(ANALOG_PIN); // Reading the op voltage of mic
  Serial.print("Raw value is : ");
  Serial.println(raw_value);
  delayMicroseconds(500); // Sampling every 500 uSec
GREEN PROBE IS DSO AND RED PROBE IS FOR DMM
BREAKOUT BOARD SCHEMATIC
BREAKOUT BOARD SCHEMATIC.png (18.48 KiB) Viewed 6531 times
CIRCUIT SCHEMATIC
mems ckt.png (8.03 KiB) Viewed 6531 times
Manveen
Re: ESP 32 with mems MIC SPW2430
Postby Manveen » Sun Sep 09, 2018 5:43 am
For anyone who is interested I have found the answer
https://forums.adafruit.com/viewtopic.php?f=8&t=140676
TLDR :
It is the mic's general behavior And no one can do anything about it
Users browsing this forum: Amazon [Bot] and 8 guests
