I verified that I could read a Spansion S25FL127 128 Mbit NOR flash using either SPI port, the VSPI port on pins 18, 19, 23 (ss = 5) and the HSPI port on pins 12, 13, 14 (ss = 15). I am pretty sure any GPIO can be the chip select but I didn't try any others. I didn't see any timing differences between the two ports and the times to read/write a page (~4500 us), erase the chip (~43 sec) were about the same between the two ports. The erase time is also about the same when erasing the same flash with an STM32L4 but the page read/write times are about ten times longer with the ESP32. Not sure why. I put the sketch to test SPI flash in my github repository (https://github.com/kriswiner/ESP32).
Are there more than two SPI ports on the ESP32? Can I use any pins for SPI or only the V and H SPI pins called out in the pinmap here (https://github.com/espressif/arduino-esp32)?
Reading SPI Flash memory
Re: Reading SPI Flash memory
That seems unusual. Same factor (x10) for both reads and writes?The erase time is also about the same when erasing the same flash with an STM32L4 but the page read/write times are about ten times longer with the ESP32. Not sure why. I put the sketch to test SPI flash in my github repository (https://github.com/kriswiner/ESP32).
If you use the GPIO Matrix then you can remap the VSPI & HSPI interfaces to any pins. This limits max clock rate to 40MHz.Are there more than two SPI ports on the ESP32? Can I use any pins for SPI or only the V and H SPI pins called out in the pinmap here (https://github.com/espressif/arduino-esp32)?
Just for completeness sake: You could also in theory connect the chip in parallel with the chip that contains the main program code, with only the /CS line connected to a different GPIO. Unfortunately, esp-idf does not support this yet.
Yes. The 4 MBytes (~3 Mbytes of space available to the user) on the board I am using is likely enough for casual use. I wanted to be able to add more.
I have a couple of add-ons I designed for a Teensy with either 16 Mbyte or 128 Mbyte. There is even an SPI NOR Flash with 256 MByte available I have used but it is pretty expensive. The point is, I thought the internal flash was limited to 16 MByte because of the addressing inside the chip Maybe this only applies to the progran flash and doesn't apply to a flash treated as an external memory anyway.
In my dev board design I didn't expose the internal flash pins so connecting to one of the SPI ports is really the only option for me.
Users browsing this forum: Applebot, Google [Bot] and 5 guests
