ESP32-LYRATD-MSC WAKE UP ALEXA
walker34
Postby walker34 » Mon Sep 24, 2018 12:07 pm
Hi everyone,
I really help about ESP32-LYRATD- MSC. I started to develop with reading datasheet for AVS and apply instructions. I downloaded this https://github.com/espressif/esp-avs-sd ... /tag/beta2 .bin files with ESP32 DOWNLOAD TOOL according to Datasheet, and adressed with true values. But when i downloaded .bin files to board, blue led of board which is communication led indicator for us is not turn on and i cant wake ALEXA. Please help me.
Note: I registered amazon website and downloaded wifi .bin file.
Screenshot (35).png (183.76 KiB) Viewed 10796 times
Screenshot (34).png (196.82 KiB) Viewed 10796 times
Screenshot (33).png (407.29 KiB) Viewed 10796 times
Amit
Re: ESP32-LYRATD-MSC WAKE UP ALEXA
Postby Amit » Tue Sep 25, 2018 6:55 am
Hi walker34,
Can you please tell what do you see on the console when the device boots up?
Also, we are planning to release new MSC release shortly which will be C based implementation of Alexa and would be much more stable and feature ready.
walker34
Postby walker34 » Tue Sep 25, 2018 12:50 pm
Hi ESP_Amit ,
I attached uart log files. I see some errors like this:
E (47) flash_parts: partition 3 invalid - offset 0x20000 size 0x300000 exceeds flash chip size 0x200000
E (57) boot: Failed to verify partition table
E (62) boot: load partition table error!
E (47) flash_parts: partition 0 invalid magic number 0x40a9
E (53) boot: Failed to verify partition table
E (58) boot: load partition table error!
please help me, i am really stuck. I want to say something , the blue ring doesn’t appears when we power the board and place the switch ON.
alexa_errormessage.txt
(1.62 KiB) Downloaded 910 times
Amit
Postby Amit » Wed Sep 26, 2018 7:01 am
Hi walker34,
Can you please try unchecking "DoNotChgBin" and check "SpiAutoSet" in the flashing utility? It appears that flash size being detected is incorrect.
walker34
Postby walker34 » Wed Sep 26, 2018 2:58 pm
Hi ESP_Amit,
Thank you for responding. I tried it, but i failed again. My dealer send new .bin files. The error which was mentioned is gone after I used new lib, but I have been giving a new trouble. The flash chip resetting by itself.
This is the error code:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
ets Jun 8 2016 00:22:57
What can I do about it?
Sincerely yours,
Can Cetin
Amit
Postby Amit » Thu Sep 27, 2018 7:29 am
Can you please post the complete console log, if any?
Also can you once try with different USB cable for power or try using a powered hub?
walker34
Postby walker34 » Thu Sep 27, 2018 9:08 am
Hi ESP_Amit,
of course , you can find SS of log file at the attachment. I tried all of advices , but i failed every time. :(
Screenshot (37).png (276.15 KiB) Viewed 10671 times
