Can we fake esp-mdf root to avoid using a router yet?
jeffdc1979
Postby jeffdc1979 » Tue Sep 25, 2018 2:47 pm
I am looking to create a multi-node mesh network that can interface with an android app only and not require the need of a router and IP address. I am hoping to be able to send data directly from the android device to the closest node in the mesh network that can act like a parent or root node to avoid having to run the data through a router ... essentially acting as a gateway to the mesh network. I have read all the other forum posts requesting this functionality and I see that it is "planned" but what is the status of it and is there a way to "hack" the code to allow for this or is it not open-source enough to allow?
magnomp
Re: Can we fake esp-mdf root to avoid using a router yet?
Postby magnomp » Thu Sep 27, 2018 9:43 pm
I'm newbie to esp32, but what you want is teoritically possible if (1) you could have low level access to android wifi interface and (2) you mimic esp-mesh protocol.
I don't think (1) is possible and (2) seems to be undocumented
yudong
Postby yudong » Fri Sep 28, 2018 12:22 pm
We could set a node as root manually using esp_mesh_set_type() or esp_mesh_set_parent() in the lastest esp-idf version. Then mesh network can be established without router.
yudong
Postby yudong » Fri Sep 28, 2018 1:33 pm
Only mesh devices can join mesh_ap,so there may be other difficulties when you try to do this.
jeffdc1979
Postby jeffdc1979 » Sat Sep 29, 2018 1:02 am
Isn't there android code to interface with the mesh network??? I am confused why you don't think this is possible or difficult?
ccrome
Postby ccrome » Tue Oct 16, 2018 2:26 am
I want to do something simmilar: I need a mesh network to exist in a location without a router. Worst case is we could use another ESP32 as an AP and have the mesh self-organize around an ESP32 AP, right?
I'm about to give this a try.
-caleb
jdatqed
Postby jdatqed » Mon Oct 29, 2018 9:13 pm
Have you tried this yet? If so, did you get it to work?
LBB
Postby LBB » Mon Dec 17, 2018 12:01 pm
Hi guys,
We've updated the MDF, and the get-started examples is a routerless demo, will that meet your requirements?
Here is the link: https://github.com/espressif/esp-mdf/tr ... et-started
