i'm following with interest the development of ESP32 IDF. I'm having hard time with the documentation (http://esp-idf.readthedocs.io/en/latest/?badge=latest). It's not impossible to use, just it's not really intuitive. I would like to know if there is any schedule for improved documentation.
Thanks,
Frax
API Documentation
Re: API Documentation
Hmm, 'non-intuitive' isn't entirely criticism we can immediately do something with... What would you like to see improved exactly?
Eheh! It's absolutely not criticism, it's more likely i'm just a newbie :\
I'm mostly interested in BT-BLE part. Actually it seems some description of the typedef/struct/commands are missing. Probably they go as granted and i'm just lacking something. I think it would be really useful adding more "operative" example, i.e. "How to create a service with 1 characteristic", "How to use advanced settings in service", "How to set permissions", etc.
I want to underline that it's not that i can't use what is available, it just would speed up the learning curve imho
Considering i'm already here i have another question. In this snippet of code of gatt example:
test_service_uuid128 is an array of 32 bytes --> 256bit but as for BT specs uuid for custom service is 128bit.
"first uuid, 16bit, [12],[13] is the value" --> what this mean? (same for bottom).
Thank you for your patience
Frax
static uint8_t test_service_uuid128[32] = {
/* LSB <--------------------------------------------------------------------------------> MSB */
//first uuid, 16bit, [12],[13] is the value
0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xAB, 0xCD, 0x00, 0x00,
//second uuid, 32bit, [12], [13], [14], [15] is the value
0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xAB, 0xCD, 0xAB, 0xCD,
};"first uuid, 16bit, [12],[13] is the value" --> what this mean? (same for bottom).
Frax
Mr Frax,
It may be that this freely downloadable book of notes might be of some use to you ... please read the description of intent found there ...
http://esp32.com/viewtopic.php?f=2&t=390&p=2522
Neil
Neil
Ah, I can imagine the BLE part is a bit lacking; it's a big thing to document and still a work in progress. I most certainly expect the usability to get better; as far as I understand it, at the moment you're basically down to manually shoving bytes into the HCI, which isn't the most user-friendly way imaginable.
@kolban:
Thank you Dr. Kolban for the interesting link. I'm following silently the (extremely useful) development of your book. Actually i still miss the updated version and i will gladly proceed to download
@ESP_Sprite:
Yes, i know it's a work in progress and i even know that it's not an high-priority update right now. That's why i was asking for any schedule for improved documentation
To be exact i'm actually at the point where i'm "breaking" your gatt_example in a set of sub-code easier to understand. The main problem is that i'm jumping from a documentation page to another, not always exhaustive, and often losing the general concept.
By the way, you answered to the original question and kolban gave me a good hint to proceed. That's enough for now
Thank you,
Frax
@ESP_Sprite:
Thank you,
Frax
Users browsing this forum: Bing [Bot] and 2 guests
