But it does not stick into the slot on module ESP32-WROOM-32U.
What kind of antennas do you use in your projects?
https://techship.com/faq/what-is-the-di ... ipex-mhf4/What is the difference between u.fl. / IPEX / MHF4?
QUESTION
SOLUTION
u.fl and IPEX are all different names for the same contact. So you can use these names interchangeably.
MHF4 is the smaller contact used with m.2/NGFF modules.
You need a wifi antenna, 2.4GHz, with U.FL (IPEX) connector.
Users browsing this forum: Bytespider, ChatGPT-User, Google [Bot] and 3 guests
