I have doit esp32 devkit v1. It has 30 pins
Shows on arduino serial monitor
rst:1x10(RTCWDT_RTC_RESET) , boot:0x1f(SPI_FAST_FLASH_BOOT)
flash read err,1000
ets_main.c 371
ets jun 8 2016 00:22:57
i removed it from circuit and tried alone but show same problem.
I used esp32 2-3 times in my circuit it worked fine but after that it malfunction and i desolder from circuit and conected to re-upload code . Now i am having trouble to upload code
I googled my problem and i assume that my boot mode change to spi from uart so Please tell me how can i change the boot mode in esp32 so i can upload codes from pc
Esp32 rebooting continuously
idahowalker
Re: Esp32 rebooting continuously
I had the same error message. I use a hardware timer and when things are fine I get a single message about the initializing status of the hardware timer. I commented out the entire contents of the hardware timer interrupt and added back in one item at a time till I found the item that caused the error and then worked to fix that item code.
Kashyapkoshti
If you search google Doit ESP32 you will find a lot of people with this problem. it appears that their design is susceptible to low voltage, especially if powered from a USB port alone. Most people have got over this by adding in another power supply to Vin or to 3.3V.. My solution is to buy from another supplier.
Kashyapkoshti
I think power is not an issue because i power it with 11.1 v li-ion battery pack and simultaneously connected with my pc to see readings in serial monitor.
And i tried again but my esp32 getting hot but not solved issue
Kashyapkoshti
How did you done that? can you provide explanation and code if required?I commented out the entire contents of the hardware timer interrupt and added back in one item at a time till I found the item that caused the error and then worked
krunalramkar
I have downgrade esp32 to 2.0.10 from Board manager or Library of esp32 in Library mangement. its solved
