Maximum current per analog input
andermutu99
Postby andermutu99 » Mon Nov 26, 2018 12:14 pm
Dear Community,
I am using analog inputs of the ESP32 WROOM32. I know that the voltage range is from 0-1V, but I am worried about how much current can the analog input handle. I have heard that the max is 12 mA and recommended 6 mA. Is that true?
Thanks in advance.
Re: Maximum current per analog input
Postby Sprite » Tue Nov 27, 2018 2:07 am
As the analog input is an (high-impedance) input, it will generally use a negligable amount of current. You can connect something to it that can source 6 or 12mA, or more, but it will never draw that much. I think you're confusing inputs and outputs: outputs can indeed source a limited amount of current, and the 12mA number is correct for the ESP8266 there, but as I mentioned before: an analog input is not an output.
Users browsing this forum: PerplexityBot and 2 guests
