DHCP server softAP slow connection to iPhone and pc
paullbart
Postby paullbart » Fri Dec 07, 2018 3:00 am
I have set up my exp32 as an access point.
When my iPhone or PC connects, in the serial monitor I get the following messages:
dhcps: send_offer>>udp_sendto result 0
this happens for somewhere between 30 seconds and over 1 minute. The phone eventually connects to the ESP and I can access its web server.
I was getting crashes on first connection attempt until I set enableAP(true), so its not crashing now at least.
Here is the following code I use to setup my access point:
    WiFi.enableSTA(false);
    WiFi.enableAP(true);
    WiFi.mode(WIFI_AP);
    delay(1000);
    WiFi.softAPConfig(local_IP, gateway, subnet);
    WiFi.softAP(SSID, PASSWORD);
    delay(1000);
the crashes I was getting were related to dhcpserver.c, but I can't find out where this is added to the build.
Is anyone else experiencing long connection times, or have any idea what the issue may be?
Paul.
