WiFi Power
chirag.sharma
WiFi Power
We have used ESP32 chip on one of our board and we are doing measurement related to WiFi Power.
We have tested WiFi Transmit Power by downloading FCC test binary "ESP32_FCC_WIFI_BT_20161208_V1.0.4.bin" on our hardware.
There is one filter circuitry at LNA_IN (Pin number 2 of ESP32) and we put one U.FL connector after this filter circuitry to measure power.
We got 15.68dBm transmit (TX) power at U.FL connector instead of 20dBm in single carrier mode (SCW).
Request you to provide feedback that why we get 15.68dBm instead of 20dBm? Also proivde us your test results for ESP32.
Note: We have taken spectrum analyzer for WiFi Power measurement
chirag.sharma
Re: WiFi Power
See pg 51. Similar result?
https://fccid.io/document.php?id=3212968
Datasheet says:
Datasheet says:
Output power of PA for 72.2 Mbps 15.5 16.5 17.5 dBm
Output power of PA for 11b mode 19.5 20.5 21.5 dBm
chirag.sharma
Re: WiFi Power
Thanks for it.
I have referred report and found that peak power is around 21dBm and average power is around 17dBm.
Actually we are using ESP32 chip and we did testing in single carrier mode.
For single carrier mode,we got peak power 15.68dBm.
Thanks for it.
Re: WiFi Power
I have 5 questions:
1.Which command did you use?
2.Which channel did you use?
3.Which rate did you use, 1Mbps?
4.Have you considered about the corrected factor?
5.Did you design the board yourself?
If you design the board yourself, I'd like you to use official module or EVB.
Re: WiFi Power
I have 5 questions:
Re: WiFi Power
I have 5 questions:
chirag.sharma
Re: WiFi Power
Please find my answers below:
Chirag: wifiscwout 1 1 0
Chirag: Channel number 1.
Chirag: We have tested single carrier mode but for further testing we have also tested power with command "wifitxout 1 0x0 0" and for that we didn't get power near to 15-16dBm, not more than that.
Chirag: As we operate in single carrier mode, I think we don't require corrected factor.
Chirag: Yes we designed board ourself.
Regarding module, we have module and EVK of ESP32 but all of them don't have U.FL connector to measure power and we don't prefer to rework EVKs and module to solder U.FL connector.
Current Status at our side: We are trying to calculate loss due to filter circuitry which is no RF line (LNA_IN pin of ESP32).
Re: WiFi Power
One more question:
What's the power you want?
I have 2 suggestions:
1.Give a picture of your test bench.
2.If we can't find the cause any way, please send a board to us.
chirag.sharma
Re: WiFi Power
We got success to get proper TX Output Power by adding 2.2nH inductor in series.
But the point is, we used recommended Pi network (same as provided in reference design) though we need to add 2.2nH inductor in series to get power.
Can anyone provide any input?
