It works well using a standard Espressif ESP32-WROOM-32 (aka ESP32-DevKitC), which uses a 40 MHz XTAL.
I'm not able to run the same example using an Allnet-IOT-WLAN https://www.allnet.de/lp/iot-wlan-display/, which uses a 26 MHz XTAL.
I suspect that the problem is related with RMT initialization. The initialization is using:
rmt_tx.clk_div = 80;Does anyone know how to use the DS18B20 sensor with ESP-IDF, using a board with a 26 MHz XTAL, instead of more standard 40 MHz one?
ESP32-WROOM-32 output (working)
Find devices:
0 : d4000008e40d7428
1 : f8000008e3632528
Found 2 devices
Device 1502162ca5b2ee28 is not present
Temperature readings (degrees C): sample 1
0: 22.3 0 errors
1: 21.8 0 errors
Temperature readings (degrees C): sample 2
0: 22.3 0 errors
1: 21.9 0 errors
Allnet-IOT-WLAN output (not working)
Find devices:
Found 0 devices
E (6780) owb_rmt: rx_items == 0
E (6880) owb_rmt: rx_items == 0
E (6980) owb_rmt: rx_items == 0
