Has anyone tried to change the server_port default vale of 80 to something else, and have it work?
I have the following and if i leave config.server_port=80 it works just fine, however if i change config.server_port=8080 it wont work.
httpd_config_t config = HTTPD_DEFAULT_CONFIG();
// Lets change this from port 80(default) to 8080
config.server_port = 8080;
http_server, server_port overide settings
Re: http_server, server_port overide settings
No one has no idea why changing server ports does not work?
Sorry about the delayed reply.
The port configuration works and can be tested using examples/protocols/http_server/advanced_tests. Here's how the configuration is set:
The server configuration structure needs to be passed to httpd_start() for this to work (as shown above). Could you please show us the part of your code where this configuration is being set?
httpd_handle_t hd;
config.server_port = 1234;
ESP_ERROR_CHECK(httpd_start(&hd, &config) );
Users browsing this forum: Amazon [Bot], Baidu [Spider], ChatGPT-User and 4 guests
