Hello,all,
My program works well with ESP32-D0WDQ6[module ESP32-wroom-32 ], while I switched to ESP32-D0WD[module ESP32-wroom-32D ], It can not boot .
It seems that the cpu1 not work. Can anybody encounter this problem, and give some tips?
Log as below:
[Codebox]
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5804
load:0x40078000,len:7684
load:0x40080000,len:7392
entry 0x4008039c
I (29) boot: ESP-IDF v3.1-beta1-41-gf198339ec 2nd stage bootloader
I (29) boot: compile time 01:37:01
I (29) boot: Enabling RNG early entropy source...
I (35) boot: SPI Speed : 40MHz
I (39) boot: SPI Mode : DIO
I (43) boot: SPI Flash Size : 4MB
I (47) boot: Partition Table:
I (51) boot: ## Label Usage Type ST Offset Length
I (58) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (65) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (73) boot: 2 factory factory app 00 00 00010000 00100000
I (80) boot: End of partition table
I (84) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x2bbc8 (179144) map
I (156) esp_image: segment 1: paddr=0x0003bbf0 vaddr=0x3ffb0000 size=0x026d4 ( 9940) load
I (160) esp_image: segment 2: paddr=0x0003e2cc vaddr=0x3ffb26d4 size=0x00000 ( 0) load
I (163) esp_image: segment 3: paddr=0x0003e2d4 vaddr=0x40080000 size=0x00400 ( 1024) load
I (172) esp_image: segment 4: paddr=0x0003e6dc vaddr=0x40080400 size=0x01934 ( 6452) load
I (183) esp_image: segment 5: paddr=0x00040018 vaddr=0x400d0018 size=0x20a8c (133772) map
I (236) esp_image: segment 6: paddr=0x00060aac vaddr=0x40081d34 size=0x078cc ( 30924) load
I (250) esp_image: segment 7: paddr=0x00068380 vaddr=0x400c0000 size=0x00000 ( 0) load
I (250) esp_image: segment 8: paddr=0x00068388 vaddr=0x50000000 size=0x00000 ( 0) load
I (262) boot: Loaded app from partition at offset 0x10000
I (262) boot: Disabling RNG early entropy source...
I (268) cpu_start: Pro cpu up.
I (272) cpu_start: Starting app cpu, entry point is 0x40080e94
[/Codebox]
Here is normal log with ESP32-D0WDQ6[module ESP32-wroom-32 ]
[Codebox]
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB0, 04:38:24
Press CTRL-A Z for help on special keys
Brownout deteets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
entry 0x4008039c
I (28) boot: ESP-IDF v3.1-beta1-41-gf198339ec 2nd stage bootloader
I (28) boot: compile time 01:37:01
I (34) boot: SPI Speed : 40MHz
I (50) boot: ## Label Usage Type ST Offset Length
I (72) boot: 2 factory factory app 00 00 00010000 00100000
I (249) esp_image: segment 7: paddr=0x00068380 vaddr=0x400c0000 size=0x00000 ( 0) load
I (271) cpu_start: Starting app cpu, entry point is 0x40080e94
I (0) cpu_start: App cpu up.
I (282) heap_init: Initializing. RAM available for dynamic allocation:
I (289) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (295) heap_init: At 3FFB3BA0 len 0002C460 (177 KiB): DRAM
I (301) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (307) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (314) heap_init: At 40089600 len 00016A00 (90 KiB): IRAM
I (320) cpu_start: Pro cpu start user code
I (2) cpu_start: Starting scheduler on PRO CPU.
[/Codebox]
Boot difference from esp32-dowdq6 to esp32d0wd?
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
- All times are UTC
- Top
- Delete cookies
About Us
Information
