ULP equivalent for rtc_gpio_init() ? [solved]
joba-1
Postby joba-1 » Mon Jan 28, 2019 1:06 am
Hi ESP32 ULP friends,
I wrote a simple ULP blink programm, and it basically works.
But my goal was to use the main core just for loading and starting the ULP code, nothing else.
Unfortunately the led at GPIO2 stays off if I don't do a rtc_gpio_init(2) in the main core first.
Is it not possible to do the equivalent from within the ULP copro?
Here is what I tried, maybe you see the error?
main.c: https://github.com/joba-1/Blink-ULP/blo ... main.c#L16
blink.S: https://github.com/joba-1/Blink-ULP/blo ... link.S#L18
// This tries to mimic rtc_gpio_init(GPIO_NUM_2), but does not work yet :(
WRITE_RTC_REG(RTC_IO_TOUCH_PAD2_REG, RTC_IO_TOUCH_PAD2_MUX_SEL_M, 1, 1)
WRITE_RTC_REG(RTC_IO_TOUCH_PAD2_REG, RTC_IO_TOUCH_PAD2_FUN_SEL_M, 1, 0)
Regards, Joachim
joba-1
Re: ULP equivalent for rtc_gpio_init() ?
Postby joba-1 » Tue Jan 29, 2019 11:29 pm
This finally did the trick:
WRITE_RTC_REG(RTC_IO_TOUCH_PAD2_REG, RTC_IO_TOUCH_PAD2_MUX_SEL_S, 1, 1)
Puzzle solved, on to the next level...
apuder
Re: ULP equivalent for rtc_gpio_init() ? [solved]
Postby apuder » Mon May 24, 2021 3:53 am
Thanks for your example! I'm trying to do the opposite: do the initialization on the main CPU and then let the ULP do the blinking. I commented out the two WRITE_RTC_REG to initialize GPIO_NUM_2 and then tried:
rtc_gpio_init(GPIO_NUM_2);
rtc_gpio_set_direction(GPIO_NUM_2, RTC_GPIO_MODE_OUTPUT_ONLY);
However, that no longer works. Any idea why?
AP
Users browsing this forum: Amazon [Bot], Bing [Bot], PerplexityBot, PetalBot and 4 guests
