I'm trying to find the PCB layout for the ESP WROVER KIT v3 but I can't find it. There are link in this page : https://dl.espressif.com/doc/esp-idf/la ... oards.html for modules layout (that send an error 404) but not for the development kits.
I'm searching for the R166 resistor but it's not clear which one is it on the PCB.
Thanks.
ESP WROVER KIT PCB Layout
Re: ESP WROVER KIT PCB Layout
Hi balix53,
You should be able to get up to date reference design links for modules here:
https://docs.espressif.com/projects/esp ... oards.html
Of interest, how did you find the link to dl.espressif.com/doc/xyz in your first post? We used to mirror docs on this site but moved to docs.espressif.com in late 2017. Will set up a redirect but also wanted to check if we have a stale set of links out there somewhere.
Regarding the board layouts for development boards, I'm not sure we've ever published these (just the schematics).
The R166 power connection can be seen in the very top right of this photo:
https://dl.espressif.com/dl/schematics/ ... kit-v3.jpg
It's larger than surrounding resistors and is marked with "0".
Thanks !It's larger than surrounding resistors and is marked with "0".
Sorry, I didn't saw that the web sites were different. I was just browsing the hardware documentation pages.Of interest, how did you find the link to dl.espressif.com/doc/xyz in your first post? We used to mirror docs on this site but moved to docs.espressif.com in late 2017. Will set up a redirect but also wanted to check if we have a stale set of links out there somewhere.
No need to apologise. It looks like some search engines were indexing https://dl.espressif.com/doc and we had not noticed. Sorry for that! These URLs should now make an attempt to redirect to the correct page on docs.espressif.com, and will hopefully drop off Google/etc soon.Sorry, I didn't saw that the web sites were different. I was just browsing the hardware documentation pages.
