ESP32 ADF + IDF
jerome
ESP32 ADF + IDF
Postby jerome » Tue Jan 29, 2019 2:44 pm
Hi All
I installed both ESP ADF and IDF.
Since ESP ADF embeds ESP IDF, does it make sense keeping ESP IDF ?
It seems the directories esp-adf/esp-idf/ is similar to the esp-idf I installed at the beginning, both contains IDF components.
Any tip would be greatly appreciated.
Re: ESP32 ADF + IDF
Postby Sprite » Wed Jan 30, 2019 4:07 am
ADF is bound to a specific version of IDF; that's the reason it's included. For ADF projects, we suggest that you use that IDF version / folder. For non-ADF projects, the choice is yours: if you're happy with whatever version ADF has, then you can delete your original IDF folder and use the one in ADF if you so prefer.
sb_espressif
Re: ESP32 ADF + IDF
Postby sb_espressif » Tue Dec 26, 2023 2:57 pm
When working with ADF, should one set IDF_PATH to point to the idf folder inside the ADF folder? Or does setting “ADF_PATH” somehow override “IDF_PATH”? Does the order of specifying these paths matter?
I’m interested specifically in understanding this with the VSCode extension; it’s unclear to me how one might set these paths per project, rather than a configuration of the extension itself.
