Getting i2s example to work on Lyrat board
audioguy
Postby audioguy » Thu Jan 31, 2019 9:56 pm
Hi guys,
Im trying to get the i2s Example form the idf library to work on my lyrat board .
https://www.espressif.com/sites/default ... ide_en.pdf
i have set the i2s ports acording to the ones i got to work in some esp-ADF example, but i dont get
sound on my headphonejack.
here is my code
/* I2S Example
    This example code will output 100Hz sine wave and triangle wave to 2-channel of I2S driver
    Every 5 seconds, it will change bits_per_sample [16, 24, 32] for i2s data
#include <stdio.h>
#include "freertos/task.h"
#include "driver/i2s.h"
#include "esp_system.h"
#include <math.h>
#define SAMPLE_RATE     (36000)
#define I2S_NUM         (0)
#define WAVE_FREQ_HZ    (100)
#define PI 3.14159265
#define SAMPLE_PER_CYCLE (SAMPLE_RATE/WAVE_FREQ_HZ)
static void setup_triangle_sine_waves(int bits)
    int *samples_data = malloc(((bits+8)/16)*SAMPLE_PER_CYCLE*4);
    unsigned int i, sample_val;
    double sin_float, triangle_float, triangle_step = (double) pow(2, bits) / SAMPLE_PER_CYCLE;
    size_t i2s_bytes_write = 0;
    printf("\r\nTest bits=%d free mem=%d, written data=%d\n", bits, esp_get_free_heap_size(), ((bits+8)/16)*SAMPLE_PER_CYCLE*4);
    triangle_float = -(pow(2, bits)/2 - 1);
    for(i = 0; i < SAMPLE_PER_CYCLE; i++) {
        sin_float = sin(i * PI / 180.0);
        if(sin_float >= 0)
            triangle_float += triangle_step;
        else
            triangle_float -= triangle_step;
        sin_float *= (pow(2, bits)/2 - 1);
        if (bits == 16) {
            sample_val = 0;
            sample_val += (short)triangle_float;
            sample_val = sample_val << 16;
            sample_val += (short) sin_float;
            samples_data[i] = sample_val;
        } else if (bits == 24) { //1-bytes unused
            samples_data[i*2] = ((int) triangle_float) << 8;
            samples_data[i*2 + 1] = ((int) sin_float) << 8;
            samples_data[i*2] = ((int) triangle_float);
            samples_data[i*2 + 1] = ((int) sin_float);
    i2s_set_clk(I2S_NUM, SAMPLE_RATE, bits, 2);
    //Using push
    // for(i = 0; i < SAMPLE_PER_CYCLE; i++) {
    //     if (bits == 16)
    //         i2s_push_sample(0, &samples_data[i], 100);
    //     else
    //         i2s_push_sample(0, &samples_data[i*2], 100);
    // or write
    i2s_write(I2S_NUM, samples_data, ((bits+8)/16)*SAMPLE_PER_CYCLE*4, &i2s_bytes_write, 100);
    free(samples_data);
void app_main()
    //for 36Khz sample rates, we create 100Hz sine wave, every cycle need 36000/100 = 360 samples (4-bytes or 8-bytes each sample)
    //depend on bits_per_sample
    //using 6 buffers, we need 60-samples per buffer
    //if 2-channels, 16-bit each channel, total buffer is 360*4 = 1440 bytes
    //if 2-channels, 24/32-bit each channel, total buffer is 360*8 = 2880 bytes
    i2s_config_t i2s_config = {
        .mode = I2S_MODE_MASTER | I2S_MODE_TX,                                  // Only TX
        .sample_rate = SAMPLE_RATE,
        .bits_per_sample = 16,
        .channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,                           //2-channels
        .communication_format = I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB,
        .dma_buf_count = 6,
        .dma_buf_len = 60,
        .use_apll = false,
        .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1                                //Interrupt level 1
   i2s_pin_config_t pin_config = {
        .bck_io_num = 5,
        .ws_io_num = 25,
        .data_out_num = 26,
        .data_in_num = -1};
    i2s_driver_install(I2S_NUM, &i2s_config, 0, NULL);
    i2s_set_pin(I2S_NUM, &pin_config);
    int test_bits = 16;
    while (1) {
        setup_triangle_sine_waves(test_bits);
        vTaskDelay(5000/portTICK_RATE_MS);
        test_bits += 8;
        if(test_bits > 32)
            test_bits = 16;
This is the i2s pinconfig
        .bck_io_num = 5,
        .ws_io_num = 25,
        .data_out_num = 26,
        .data_in_num = -1};
Do i need to do something different if i want to play it on headphones instead of the speaker output of the board?
Thanks in advance :)
krzychb
Contact:
Re: Getting i2s example to work on Lyrat board
Postby krzychb » Thu Jan 31, 2019 10:28 pm
Hi audioguy,
Yes, you need to configure an audio codec chip on board of ESP32-LyraT. Both the headphones and the speaker are connected to this audio chip. Please try respective examples in esp-adf/examples/ that contain a driver for this codec.
audioguy
Postby audioguy » Fri Feb 01, 2019 8:19 pm
Thanks for that tip, but I don't really understand what is meant by "configure an audio codec chip" I use the same
 i2s_config
as the ESP-adf example which seems to work.
would that be something I need to do in the project setup (makefiles act.) or is there another "driver/i2s. h" I could include somehow?
I would use the ESP-adf pipeline, but I cant get it to play to my headphones and let me see what raw samples its writing to the i2s stream_writer.
I've tried the
audio_element_set_write_cb(i2s_stream_reader, i2s_input_write_cb, NULL);
function, but I probably overwrite the part calling i2s_write with this callback and I don't know how to prevent it
krzychb
Contact:
Postby krzychb » Fri Feb 01, 2019 10:12 pm
Hi audioguy,
By "configure an audio codec chip" I meant running https://github.com/espressif/esp-adf/bl ... .c#L56-L57
Just checked play_mp3 example on ESP-LyraT V4.3 and it works properly with the headphones.
Users browsing this forum: Qwantbot, Semrush [Bot] and 2 guests
