Getting i2s example to work on Lyrat board
Posted: Thu Jan 31, 2019 9:56 pm
Hi guys,
Im trying to get the i2s Example form the idf library to work on my lyrat board .
https://www.espressif.com/sites/default ... ide_en.pdf
i have set the i2s ports acording to the ones i got to work in some esp-ADF example, but i dont get
sound on my headphonejack.
here is my code
This is the i2s pinconfig
Do i need to do something different if i want to play it on headphones instead of the speaker output of the board?
Thanks in advance
here is my code
/* I2S Example
This example code will output 100Hz sine wave and triangle wave to 2-channel of I2S driver
Every 5 seconds, it will change bits_per_sample [16, 24, 32] for i2s data
This example code is in the Public Domain (or CC0 licensed, at your option.)
Unless required by applicable law or agreed to in writing, this
software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
CONDITIONS OF ANY KIND, either express or implied.
#include <stdio.h>
#include "freertos/task.h"
#include "driver/i2s.h"
#include "esp_system.h"
#include <math.h>
#define SAMPLE_RATE (36000)
#define I2S_NUM (0)
#define WAVE_FREQ_HZ (100)
#define PI 3.14159265
#define SAMPLE_PER_CYCLE (SAMPLE_RATE/WAVE_FREQ_HZ)
static void setup_triangle_sine_waves(int bits)
int *samples_data = malloc(((bits+8)/16)*SAMPLE_PER_CYCLE*4);
unsigned int i, sample_val;
double sin_float, triangle_float, triangle_step = (double) pow(2, bits) / SAMPLE_PER_CYCLE;
size_t i2s_bytes_write = 0;
printf("\r\nTest bits=%d free mem=%d, written data=%d\n", bits, esp_get_free_heap_size(), ((bits+8)/16)*SAMPLE_PER_CYCLE*4);
triangle_float = -(pow(2, bits)/2 - 1);
for(i = 0; i < SAMPLE_PER_CYCLE; i++) {
sin_float = sin(i * PI / 180.0);
if(sin_float >= 0)
triangle_float += triangle_step;
else
triangle_float -= triangle_step;
sin_float *= (pow(2, bits)/2 - 1);
if (bits == 16) {
sample_val = 0;
sample_val += (short)triangle_float;
sample_val = sample_val << 16;
sample_val += (short) sin_float;
samples_data[i] = sample_val;
} else if (bits == 24) { //1-bytes unused
samples_data[i*2] = ((int) triangle_float) << 8;
samples_data[i*2 + 1] = ((int) sin_float) << 8;
} else {
samples_data[i*2] = ((int) triangle_float);
samples_data[i*2 + 1] = ((int) sin_float);
i2s_set_clk(I2S_NUM, SAMPLE_RATE, bits, 2);
//Using push
// for(i = 0; i < SAMPLE_PER_CYCLE; i++) {
// if (bits == 16)
// i2s_push_sample(0, &samples_data[i], 100);
// else
// i2s_push_sample(0, &samples_data[i*2], 100);
// or write
i2s_write(I2S_NUM, samples_data, ((bits+8)/16)*SAMPLE_PER_CYCLE*4, &i2s_bytes_write, 100);
free(samples_data);
void app_main()
//for 36Khz sample rates, we create 100Hz sine wave, every cycle need 36000/100 = 360 samples (4-bytes or 8-bytes each sample)
//depend on bits_per_sample
//using 6 buffers, we need 60-samples per buffer
//if 2-channels, 16-bit each channel, total buffer is 360*4 = 1440 bytes
//if 2-channels, 24/32-bit each channel, total buffer is 360*8 = 2880 bytes
i2s_config_t i2s_config = {
.mode = I2S_MODE_MASTER | I2S_MODE_TX, // Only TX
.sample_rate = SAMPLE_RATE,
.bits_per_sample = 16,
.channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT, //2-channels
.communication_format = I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB,
.dma_buf_count = 6,
.dma_buf_len = 60,
.use_apll = false,
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1 //Interrupt level 1
i2s_pin_config_t pin_config = {
.bck_io_num = 5,
.ws_io_num = 25,
.data_out_num = 26,
.data_in_num = -1};
i2s_driver_install(I2S_NUM, &i2s_config, 0, NULL);
i2s_set_pin(I2S_NUM, &pin_config);
int test_bits = 16;
while (1) {
setup_triangle_sine_waves(test_bits);
vTaskDelay(5000/portTICK_RATE_MS);
test_bits += 8;
if(test_bits > 32)
test_bits = 16;
}Code: Select all
.bck_io_num = 5,
.ws_io_num = 25,
.data_out_num = 26,
.data_in_num = -1};
Thanks in advance
