I'm using VisualGDB with ESP-IDF V3.2.
When I try to compile the "protocols\http_server\simple\" the include file "esp_http_server.h" ist not found.
What is wrong, how can I fix it?
Regards
Joerg
esp_http_server not included/linked
Re: esp_http_server not included/linked
Though it is not direct answer, but hope it will help. You can use lwip library to manage network communication. Here is an excellent link to tutorial.
http://www.lucadentella.it/en/2017/07/0 ... ebserver/
http://www.lucadentella.it/en/2017/01/3 ... sione-tcp/
Its light weight and made for embedded systems.
https://savannah.nongnu.org/projects/lwip/
@JSchaef Seems like your IDF_PATH is not set correctly. Could you make sure that's not the case
Users browsing this forum: Amazon [Bot], coccocbot, PetalBot and 5 guests
