NEW LIBRARY FOR UPNP (HELP US IMPROVE)
lucasromeiro
Postby lucasromeiro » Sun Feb 03, 2019 1:02 pm
Hello everyone!
Some time ago I've been looking for a solution to connect to my remote devices installed on clients.
It is inconvenient to ask them to do port redirection. This has bothered me a lot.
I need something simpler and more practical.
Then I read about UPnP.
I researched and found a library that does this, but at the time it did not work well and was not in the arduino's libraryManager.
A little while ago it has been added and has received interesting updates.
I believe that many people here would also make good use of this library.
It does port redirection automatically.
I also invite those who like to help, help me make this library reliable and robust!
I have been helping and testing.
Anyone who can help will also be welcome!
A simple test on your router to tell if it worked will help a lot! You will also be welcome to help develop improvements.
Library:
https://github.com/ofekp/TinyUPnP
Thank you all!
Angus
Re: NEW LIBRARY FOR UPNP (HELP US IMPROVE)
Postby Angus » Sun Feb 03, 2019 10:25 pm
Moderator's note: Moved to Arduino subforum as this is an Arduino library.
Thanks for sharing the library with us!
lucasromeiro
Postby lucasromeiro » Sun Feb 03, 2019 10:54 pm
Some of you have a MCU node and 15 minutes to do a test for me?
I'm helping a colleague upgrade the UPnP library to port forward automatically to the router that has the function enabled.
I tested the 2 routers I have, but it needs more testing on other routers to try to find a bug.
The more people you test and can send me the log, it will help a lot!
Just record this program on your node mcu, put the ssid and password of your wifi in the code before compiling.
Turn on the serial monitor on 115200.
Save in a txt file the LOG that it spits in the serial.
Send me that I refer to him. (you can send me the private txt if you do not want to post here)
I thank everyone who can help.
upnp test.zip
(13.54 KiB) Downloaded 581 times
