bug in esp_mesh_send sending to ROOT
leenowell
Postby leenowell » Sat Feb 09, 2019 2:44 pm
Hi all,
I am having some trouble with esp_mesh_send. The following code runs on 2 x ESP32s and seems to work fine if the node is ROOT but if it is not ROOT I get the following errors
[0;32mI (1065587) HomeIoT: DoStuff: leaf node[0m
[0;32mI (1065587) HomeIoT: DoStuff: About to send message [Hello from HomeIOT] size [19] layer[2] numb nodes[1][0m
[0;32mI (1065587) mesh_node: MeshNodeSendData:  message size [19] message [Hello from HomeIOT][0m
[0;32mI (1065597) mesh_node: Destination is NULL so off to ROOT[0m
[0;31mE (1065597) mesh_node: MeshNodeSendData: Failed to send Mesh data Error[16392 = ESP_ERR_MESH_ARGUMENT] - message size [19] parent [ 3c:71:bf:96:e6:41 ] [0m
[0;31mE (1065617) HomeIoT: DoStuff: Failed to send Mesh data to ROOT Error[16392 = ESP_ERR_MESH_ARGUMENT] - Message [Hello from HomeIOT][0m
This is the function that sends the mesh data
esp_err_t mesh_node_send_data(mesh_addr_t *dest_addr, mesh_data_t *data)
    esp_err_t err = ESP_OK;
    char *sMessage = (char*)data->data;
	ESP_LOGI(MESH_TAG,"MeshNodeSendData:  message size [%d] message [%s]", data->size, sMessage );
	err = esp_mesh_send(dest_addr, data, MESH_DATA_P2P, NULL, 0);
    if (mesh_parent_addr.addr == NULL)
    	ESP_LOGE(MESH_TAG, "MeshNodeSendData: parent address is NULL");
    	return ESP_FAIL;
    if (err != ESP_OK)
    	ESP_LOGE(MESH_TAG,"MeshNodeSendData: Failed to send Mesh data Error[%d = %s] - message size [%d] parent [ "MACSTR" ] ", err, esp_err_to_name(err), data->size, MAC2STR(mesh_parent_addr.addr) );
	else
    	ESP_LOGI(MESH_TAG,"MeshNodeSendData: Sent Mesh message -  message size [%d] parent ["MACSTR"] ", data->size, MAC2STR(mesh_parent_addr.addr) );
    return err;
and this is the calling code
void DoStuff()
	char sMessage[40] = "";
	esp_err_t err;
	mesh_addr_t routeTable[100];
	int nRouteTableSize = 0;
	int nLayer = 0;
	bool bIsRoot = false;
	sprintf(sMessage, "Hello from HomeIOT");
	mesh_data_t data;
	data.data = (void*) sMessage;
	data.size = strlen((char*) data.data)+1;
	data.proto = MESH_PROTO_BIN;
    data.tos = MESH_TOS_DEF;
	while (1)
		bIsRoot = esp_mesh_is_root();
		if (bIsRoot)
			ESP_LOGI(HOMEIOT_TAG, "DoStuff: I AM ROOT");
		else
			ESP_LOGI(HOMEIOT_TAG, "DoStuff: leaf node");
		// Only gives table of this node and those below
		err = esp_mesh_get_routing_table( (mesh_addr_t*) &routeTable, 100*6, &nRouteTableSize);
		nLayer =  esp_mesh_get_layer();
		ESP_LOGI(HOMEIOT_TAG, "DoStuff: About to send message [%s] size [%d] layer[%d] numb nodes[%d]", (char*) data.data, data.size, nLayer, nRouteTableSize);
		err = mesh_node_send_data( NULL ,  &data);
		if (err !=ESP_OK)
			ESP_LOGE(HOMEIOT_TAG, "DoStuff: Failed to send Mesh data to ROOT Error[%d = %s] - Message [%s]", err ,esp_err_to_name(err), (char *) data.data);
		vTaskDelay(5 * 1000 / portTICK_RATE_MS);
This seems like a bug to me but anyone have any ideas?
thanks
Lee.
leenowell
update bug in esp_mesh_send sending to ROOT
Postby leenowell » Sun Feb 10, 2019 1:34 pm
Hi All,
UPDATED after further testing - sorry
So after a lot of debugging and trying all sorts of things, I *think* I may have found something - initially I thought this was the culprit but after more testing looks like it is not. Having said this, the internal_communication one does seem to still be the case but making the changes in my code still has the invalid argument error - so back to the drawing board :(
The data I am sending is a struct. If I create an instance of it within my send function and set the "mesh_data_t.data" element to point to it I get the error. If I just move the instance of the struct to be a global variable it works fine.
This code (simplified to highlight the issue) gives the error
MySendFunction()
	mesh_data_t dataToRoot;
	homeiot_message_t homeiotSendMessage;
	homeiotSendMessage.event = NODE_DATA;
	dataToRoot.data 	= (void*) &homeiotSendMessage;
	dataToRoot.size 	= sizeof(homeiotSendMessage);
	err = mesh_node_send_data( NULL ,  &dataToRoot);
Where as this code works fine
MySendFunction()
The internal_communication example behaves similarly however the error is different. Instead of "ESP_ERR_MESH_ARGUMENT" it returns "ROOT-2-UNICAST".
I assume this is a bug in the mesh send function as not sure why it rejects (or indeed knows) when the data it points to is on the stack. Using a global variable will potentially cause concurrency issues. Would be interested in your thoughts.
thanks
Lee.
leenowell
Re: bug in esp_mesh_send sending to ROOT
Postby leenowell » Sun Feb 10, 2019 5:00 pm
Sorry please disregard the previous post as I can now reproduce the error even with the data variable being global. Only other update to give is that even with logging set to "verbose" I get no log output during the call to esp_mesh_send. I log immediately before and after it and that's all I get.
thanks
Lee.
leenowell
Postby leenowell » Tue Feb 12, 2019 7:49 am
Hi
Any thoughts on this? Even if you could tell me what the error means eg which argument or what sort of checks it does maybe I could dig in a bit further ?
Lee.
leenowell
Postby leenowell » Thu Feb 14, 2019 12:11 pm
Hi all
Any thoughts in this? Happy to run any further tests to help identify the issue.
Lee.
hassan789
Postby hassan789 » Sun Jul 21, 2019 1:52 am
having the same problem from time to time... must be a bug in the MDF/IDF layer...
brtcld
Postby brtcld » Tue Nov 18, 2025 7:58 am
same problem on ESP32S3 ... IDF v.5.4. When root is off and child node send a message to the root, sometimes mesh task enters an infinite loop
due to esp_mesh_send retransmissions. The esp_mesh_send_block_time function appears to have no effect. If you set data.tos = MESH_TOS_DEF, esp_mesh_send returns INVALID_ARGUMENT.
Users browsing this forum: Amazon [Bot], Applebot, Baidu [Spider], Bing [Bot], PetalBot and 1 guest
