I use "Espressif IoT Development Framework. Official development framework for ESP32", i2s bck and ws is ok,but
my adc need mclk,how can i open esp32 mclk? (stm32 cpu i2s include mclk, bck, ws ) thank you.
i2s mclk
Re: is2 mclk
We do not have a separate mclk output from the i2S driver, sorry. If your I2S codec is happy with a non-synchronized mclk (which a fair few are, in my experience) you can generate this using e.g. the LED PWM module.
Re: is2 mclk
The LED PWM module cannot be used to generate the MCLK required for I2S. MCLK requires at a rate of 64x to 256x of the sampling rate. The max. frequency that can be generated by this module is 78.125KHz (= 80MHz / 1024), so, don't try to make use of it. I want to take a look at PWM0~3 modules for generating the MCLK, but there is no information about them.
Colman
Colman
Re: is2 mclk
That's not entirely true. The hardware happily supports a divider of e.g. 2, leading to a 40MHz signal. The driver actually also supports this, but not in an obvious way: the led_timer_bit_t structure you use to select the depth only has 10 to 15-bit options. However, if instead you feed a literal '1' into the setup function instead of one of the enum values, it should work just fine to give you an 1-bit counter. The same goes for any other literal number in the 1-20 range. I'm not sure why we did not include the other bit options as well, to be honest.
Users browsing this forum: Applebot, Bing [Bot], Qwantbot and 8 guests
