Polling SPI Inside Timer Interrupt
e2738729
Postby e2738729 » Wed Feb 27, 2019 3:18 am
Hi everyone,
I have a conceptual question that hopefully you could help me figure out. I am not sure sharing my codes is a good idea since it spans 3 C files and 3 H files. But anyway here is the symptom:
I have a timer interrupt that runs at 500 Hz. Whenever I have a SPI polling program inside the interrupt, the esp32 crash and display the following on the monitor:
Toolchain path: /home/khoi/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: crosstool-ng-1.22.0-80-g6c4433a
Compiler version: 5.2.0
Python requirements from /home/khoi/esp/esp-idf/requirements.txt are satisfied.
MONITOR
--- idf_monitor on /dev/ttyUSB1 115200 ---
 fini�ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:8500
load:0x40078000,len:11960
load:0x40080400,len:7060
entry 0x400807a0
D (61) bootloader_flash: mmu set block paddr=0x00000000 (was 0xffffffff)
I (39) boot: ESP-IDF v3.3-beta1-324-g2790d4a 2nd stage bootloader
I (39) boot: compile time 19:37:09
D (39) boot: Enabling RTCWDT(9000 ms)
I (52) boot: Enabling RNG early entropy source...
D (52) boot: magic e9
D (52) boot: segments 04
D (53) boot: spi_mode 02
D (56) boot: spi_speed 00
D (59) boot: spi_size 02
I (61) boot: SPI Speed      : 40MHz
I (65) boot: SPI Mode       : DIO
I (69) boot: SPI Flash Size : 4MB
D (73) bootloader_flash: mmu set paddr=00000000 count=1 size=c00 src_addr=8000 src_addr_aligned=0
D (82) boot: mapped partition table 0x8000 at 0x3f408000
D (88) flash_parts: partition table verified, 4 entries
I (93) boot: Partition Table:
I (97) boot: ## Label            Usage          Type ST Offset   Length
D (104) boot: load partition table entry 0x3f408000
D (109) boot: type=1 subtype=2
I (112) boot:  0 nvs              WiFi data        01 02 00009000 00006000
D (120) boot: load partition table entry 0x3f408020
D (125) boot: type=1 subtype=1
I (128) boot:  1 phy_init         RF data          01 01 0000f000 00001000
D (135) boot: load partition table entry 0x3f408040
D (140) boot: type=0 subtype=0
I (143) boot:  2 factory          factory app      00 00 00010000 00100000
I (151) boot: End of partition table
D (155) boot: Trying partition index -1 offs 0x10000 size 0x100000
D (161) esp_image: reading image header @ 0x10000
D (166) bootloader_flash: mmu set block paddr=0x00010000 (was 0xffffffff)
D (173) esp_image: image header: 0xe9 0x06 0x02 0x01 40081218
I (179) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x1cd80 (118144) map
D (188) bootloader_flash: mmu set paddr=00010000 count=2 size=1cd80 src_addr=10020 src_addr_aligned=10000
D (239) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff)
I (239) esp_image: segment 1: paddr=0x0002cda8 vaddr=0x3ffb0000 size=0x031e8 ( 12776) load
D (243) bootloader_flash: mmu set paddr=00020000 count=1 size=31e8 src_addr=2cda8 src_addr_aligned=20000
D (258) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff)
I (260) esp_image: segment 2: paddr=0x0002ff98 vaddr=0x40080000 size=0x00078 (   120) load
0x40080000: _WindowOverflow4 at /home/khoi/esp/esp-idf/components/freertos/xtensa_vectors.S:1779
D (269) bootloader_flash: mmu set paddr=00020000 count=2 size=78 src_addr=2ff98 src_addr_aligned=20000
D (278) bootloader_flash: mmu set block paddr=0x00030000 (was 0xffffffff)
I (285) esp_image: segment 3: paddr=0x00030018 vaddr=0x400d0018 size=0x6b454 (439380) map
0x400d0018: _stext at ??:?
D (294) bootloader_flash: mmu set paddr=00030000 count=7 size=6b454 src_addr=30018 src_addr_aligned=30000
D (457) bootloader_flash: mmu set block paddr=0x00090000 (was 0xffffffff)
I (458) esp_image: segment 4: paddr=0x0009b474 vaddr=0x40080078 size=0x00388 (   904) load
0x40080078: _xt_alloca_exc at /home/khoi/esp/esp-idf/components/freertos/xtensa_vectors.S:1841
D (462) bootloader_flash: mmu set paddr=00090000 count=1 size=388 src_addr=9b474 src_addr_aligned=90000
D (472) bootloader_flash: mmu set block paddr=0x00090000 (was 0xffffffff)
I (478) esp_image: segment 5: paddr=0x0009b804 vaddr=0x40080400 size=0x12674 ( 75380) load
D (487) bootloader_flash: mmu set paddr=00090000 count=2 size=12674 src_addr=9b804 src_addr_aligned=90000
D (528) bootloader_flash: mmu set block paddr=0x000a0000 (was 0xffffffff)
D (528) esp_image: Calculated hash: 97de951fd0471d655e356638f626a26ce3aa73e00461abaa24eb022c0e3ebf31
D (533) bootloader_flash: mmu set paddr=000a0000 count=1 size=20 src_addr=ade80 src_addr_aligned=a0000
D (543) bootloader_flash: mmu set paddr=000a0000 count=1 size=20 src_addr=ade80 src_addr_aligned=a0000
I (563) boot: Loaded app from partition at offset 0x10000
I (563) boot: Disabling RNG early entropy source...
D (563) boot: Mapping segment 0 as DROM
D (567) boot: Mapping segment 3 as IROM
D (571) boot: calling set_cache_and_start_app
D (576) boot: configure drom and irom and start
D (580) boot: start: 0x40081218
0x40081218: call_start_cpu0 at /home/khoi/esp/esp-idf/components/esp32/cpu_start.c:121
I (584) cpu_start: Pro cpu up.
I (587) cpu_start: Application information:
I (592) cpu_start: Project name:     ESP_ADS_WLAN
I (597) cpu_start: App version:      1
I (602) cpu_start: Compile time:     19:37:08
I (607) cpu_start: Compile date:     Feb 26 2019
I (612) cpu_start: ESP-IDF:          v3.3-beta1-324-g2790d4a
I (619) cpu_start: Starting app cpu, entry point is 0x400811c4
0x400811c4: call_start_cpu1 at /home/khoi/esp/esp-idf/components/esp32/cpu_start.c:265
I (0) cpu_start: App cpu up.
I (629) heap_init: Initializing. RAM available for dynamic allocation:
I (636) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (642) heap_init: At 3FFD0928 len 0000F6D8 (61 KiB): DRAM
I (648) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (654) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (661) heap_init: At 40092A74 len 0000D58C (53 KiB): IRAM
I (667) cpu_start: Pro cpu start user code
I (14) esp_core_dump: Init core dump to UART
E (15) esp_core_dump: No core dump partition found!
I (15) cpu_start: Starting scheduler on PRO CPU.
I (85) tcp_perf:: ESP_WIFI_MODE_STA
I (105) wifi: wifi driver task: 3ffd7c94, prio:23, stack:3584, core=0
I (105) wifi: wifi firmware version: 6b5b696
I (105) wifi: config NVS flash: enabled
I (105) wifi: config nano formating: disabled
I (115) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (125) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (155) wifi: Init dynamic tx buffer num: 32
I (155) wifi: Init data frame dynamic rx buffer num: 32
I (155) wifi: Init management frame dynamic rx buffer num: 32
I (155) wifi: Init static rx buffer size: 1600
I (165) wifi: Init static rx buffer num: 10
I (165) wifi: Init dynamic rx buffer num: 32
I (325) phy: phy_version: 4100, 6fa5e27, Jan 25 2019, 17:02:06, 1, 0
I (325) wifi: mode : sta (30:ae:a4:bc:0f:cc)
I (325) tcp_perf:: wifi_init_sta finished.
I (335) tcp_perf:: connect to ap SSID:ESP32 2.4 password:Cao5566thU
I (455) wifi: new:<1,0>, old:<1,0>, ap:<255,255>, sta:<1,0>, prof:1
I (1435) wifi: state: init -> auth (b0)
I (1435) wifi: state: auth -> assoc (0)
I (1455) wifi: state: assoc -> run (10)
Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC      : 0x40084cf9  PS      : 0x00060031  A0      : 0x80084e8f  A1      : 0x3ffb0d60
0x40084cf9: spi_device_polling_start at /home/khoi/esp/esp-idf/components/driver/spi_master.c:547
A2      : 0x00000000  A3      : 0x3ffb0db0  A4      : 0xffffffff  A5      : 0x3ffd7b60
A6      : 0x3ffd13d0  A7      : 0x00000000  A8      : 0x3ffd67f0  A9      : 0x00000000
A10     : 0x0000000a  A11     : 0x3ffd7b40  A12     : 0x8010962f  A13     : 0x3ffd7b30
A14     : 0x3ffcdd64  A15     : 0x3ffd13ec  SAR     : 0x0000001b  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000040  LBEG    : 0x4000c2e0  LEND    : 0x4000c2f6  LCOUNT  : 0xffffffff
Core 0 was running in ISR context:
EPC1    : 0x40084cf9  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x00000000
Backtrace: 0x40084cf9:0x3ffb0d60 0x40084e8c:0x3ffb0d90 0x400d2f71:0x3ffb0db0 0x400d30b2:0x3ffb0e00 0x400d3179:0x3ffb0e30 0x4008257d:0x3ffb0e50 0x401085b4:0x3ffd7ad0 0x40086ba5:0x3ffd7af0 0x401091ba:0x3ffd7b30 0x4010962c:0x3ffd7b60 0x40109969:0x3ffd7b90 0x4008847d:0x3ffd7bc0 0x4008fc9d:0x3ffd7c00
0x40084e8c: spi_device_polling_transmit at /home/khoi/esp/esp-idf/components/driver/spi_master.c:547
0x400d2f71: ADS1256_REG at /home/khoi/esp/workspace/ESP_ADS_WLAN/main/adc_collector.c:61
0x400d30b2: ADS1256_Collect at /home/khoi/esp/workspace/ESP_ADS_WLAN/main/adc_collector.c:162 (discriminator 2)
0x400d3179: timer_isr at /home/khoi/esp/workspace/ESP_ADS_WLAN/main/adc_collector.c:117
0x4008257d: _xt_lowint1 at /home/khoi/esp/esp-idf/components/freertos/xtensa_vectors.S:1154
0x401085b4: esp_wifi_internal_set_msdu_lifetime at ??:?
0x40086ba5: lmacTxFrame at ??:?
0x401091ba: esp_wifi_internal_set_msdu_lifetime at ??:?
0x4010962c: lmacProcessAckTimeout at ??:?
0x40109969: lmacProcessTxComplete at ??:?
0x4008847d: ppTask at ??:?
0x4008fc9d: vPortTaskWrapper at /home/khoi/esp/esp-idf/components/freertos/port.c:403
I (1523) esp_core_dump: Press Enter to print core dump to UART...
I (1529) esp_core_dump: Print core dump to uart...
================= CORE DUMP START =================
7BsAAAEAAAAJAAAAZAEAAA==
sBX9P5De/T+43/0/
kN79P1Df/T8AAAAAdDz7P3Q8+z+wFf0/bDz7PxQAAAAAAAAAAAAAALAV/T8AAAAA
BQAAALzP/T90Y3BfY29ubgAAAAAAAAAA////f7jf/T8AAAAAIAQGAAUAAAACAAAA
AAAAAAAAAAAAAAAArOj6PxTp+j986fo/AAAAAAAAAAABAAAAAAAAADBQQD8AAAAA
SB0AQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAA=
oPwIgPDe/T8MMEA/AAAAANDe/T+w3v0/DAAAAAAAAAAAAAAANC0NQAAAAADDBQAA
DDBAPyMPBgAAAAAAAAAAABgwQD8fAAAAAQAAAAUAAAAAAAAAMN/9PzQtDUAAAAAA
AAAAAAAAAAAAAAAAAAAAAMAR/D8AAAAAAAAAAAAAAAAjAAYAsBX9PwAAAAAAAAAA
AAAAAFDf/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAABc3/0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAA=
WC79P7As/T9QLv0/
sCz9P/At/T9WCPJYzDP9PxA8+z9YLv0/CDz7PxkAAACEkNa3+dVlYVgu/T8AAAAA
AAAAAFQq/T9JRExFMADx9LCElA8864AAAAAAAFAu/T8AAAAAIwAGAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAHa/4=
GCMIQHqjE0AwDQYASicNgHAt/T8AAAAAAQAAAAAAAAABAAAAAwAAACMIBgASJg2A
QC39PwAAAABELAhAIA0GAAEAAAAgDQYAAQAAAAAAAABgYPs/AAAAAAAAAAAAAAAA
AAAAABglCEABAAAAtBsJQGBg+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAACUDAlAAAAAAAAAAACgDAmAkC39PwgAAAAAAAAA
AAAAAAEAAAADAAAAIwgGAKD8CICwLf0/AAAAAAAAAAABAAAAAQAAACEABgAAAAAA
AAAAANAt/T+UDAlAAAAAACMABgDEM/0/AAAAAAEAAAAAAAAA8C39PwAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPwt/T8AAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
xDP9PxAy/T+8M/0/
EDL9P1Az/T/MraC7EDz7P2Au/T/EM/0/CDz7PxkAAAD9mw+NJ1KT6sQz/T8AAAAA
AAAAAMAv/T9JRExFMQAi37LJMMURA7EAAQAAALwz/T8AAAAAIQAGAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAACuRPc=
GCMIQHqjE0AwDwYASicNgNAy/T8AAAAAAQAAgAAAAAABAAAAAwAAACMABgASJg2A
oDL9PwAAAAAjCgYAIAoGAAEAAAAgCgYA8EH9PwAAAAAHJg2AgDL9PwAAAAAAAAAA
AAAAABglCEABAAAAtBsJQMBl+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAACAKBgABAAAAIAoGAPBB/T+gDAmA8DL9PwgAAAABAAAA
AAAAAAEAAAADAAAAIwAGAKD8CIAQM/0/AAAAAAAAAAABAAAAAQAAACEABgAAAAAA
AAAAADAz/T+UDAlAAAAAACMABgBYLv0/AAAAAAEAAAAAAAAAUDP9PwAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFwz/T8AAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
FFP9PwBR/T8MU/0/
AFH9P6BS/T+PAAAA/Dv7P/w7+z8UU/0/9Dv7PwcAAABoSP0/aEj9PxRT/T9gSP0/
EgAAABBJ/T90aVQAZAcAIAAABMAAEAQA////fwxT/T8AAAAAIQAGABIAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAKAAI=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cDz9P7A9/T8AAAAA6Dv7P+g7+z8kPv0/4Dv7PxgAAABYNf0/WDX9PyQ+/T9QNf0/
AQAAACA2/T9UbXIgU3ZjANRfboPgxUUAAAAAABw+/T8AAAAAIQAGAAEAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAACIMV4=
GCMIQGgZCUAwCAYAWxoJgDA9/T8IPvs/AAAAAAEAAAABAAAAIQAGAAAAAABoGQmA
ED39PwAAAABgO/s/dDX9PwAAAAAAAAAAIwAGAAAAAAClpaWlpaWlpQAAAAAAAAAA
AAAAABglCEAAAAAAtBsJQCBw+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAABMGglAAAAAAAAAAACg/AiAYD39PwAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkD39P0waCUAAAAAA
AQAAAAAAAAAAAAAAAAAAACMABgDsKP0/AAAAAAEAAAAAAAAAsD39PwAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALw9/T8AAAAA
oBH9P/AP/T+YEf0/
8A/9PzAR/T94Don8hGX9P2z++j+gEf0/hDv7PwEAAAB0Df0/dA39P6AR/T9sDf0/
GAAAAJwN/T9pcGMxAHE9aSVD/ZTAdU0AAQAAAJgR/T8AAAAAIQAGABgAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAABwk8Q=
GCMIQP36CEAwAQYAiyEIgLAQ/T9IDf0/AAAAAJAN/T8AAAAAAQAAAAAAAAD9+giA
kBD9PwEAAAD8Pfs/AD77PwoAAAAAAIAAHAD0PwAAAACgQ/s/AAAAAAAAAAAAAAAA
AAAAABglCEAKAAAAtBsJQKBD+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAEAAAABAAAAIAEGACMABgCg/AiA8BD9PwEAAAC8NQhA
AAAAABEAAAAAAIAAHAD0P//////wEP0/AQAAALw1CECQDf0/AAAAAAEAAAAAAAAA
AAAAABAR/T9cIQhAAQAAAAEAAACgEf0/AAAAAAAAAAAAAAAAMBH9PwAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAABgSCICAff4/KAAAACgAAAAAAAAAAAAAADwR/T8AAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
fGX9P6Bj/T90Zf0/
oGP9PxBl/T8CIQQABPv6P6gR/T98Zf0/hDv7PwUAAABQVf0/UFX9P3xl/T9IVf0/
FAAAAHhb/T9ldmVudFRhc2sAAAAAIEAAAAAAAHRl/T8AAAAAIQAGABQAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAABQAUM=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UPn6P5D6+j81xZ6UjDv7P4Rl/T/8+vo/hDv7PwMAAAB86vo/fOr6P/z6+j906vo/
FgAAAPjq+j9lc3BfdGltZXIAEnIOcQMAAAAAAPT6+j8AAAAAIQAGABYAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAVUZ8=
GCMIQP36CEAwAwYAmx8NgBD6+j9Q6vo/AAAAAJjq+j8AAAAAAQAAAAAAAAD9+giA
8Pn6PwAAAAD8Pfs//D37P/AL/T8DAAAAIw4GAAAAAAA0+AiA0Pn6P+DCAED2wgBA
/////xglCEDwC/0/tBsJQAAt+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAOzq+j8AAAAAAAAAAAAAAACg/AiAUPr6PwAAAAAAAAAA
AAAAAIoAAAADAAAAIw4GAP////9Q+vo/AAAAAAAAAACY6vo/AAAAAFDq+j8AAAAA
AAAAAHD6+j+IHw1AAAAAACMABgD8+vo/AAAAAAEAAAAAAAAAkPr6PwAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJz6+j8AAAAA
ZP76P6AL/T9ADf0/
oAv9P+AM/T9O+GxJqBH9P4w7+z9k/vo/hDv7PwEAAAA8/vo/PP76P2T++j80/vo/
GAAAAEQJ/T9pcGMwAFVyX85Pq/wE+H0AAAAAAEAN/T8AAAAAIQAGABgAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAABnD3c=
GCMIQP36CEAwDgYAiyEIgGAM/T8Q/vo/AAAAAFj++j8AAAAAAQAAAAIAAAD9+giA
QAz9PwAAAAD8Pfs//D37P83NAAABAAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
AAAAABglCEDNzQAAtBsJQFA/+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAABcIQhAAAAAAAAAAACg/AiAoAz9PwAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAMAM/T9cIQhAAAAAACMDBgBk/vo/AQAAAAEAAAAAAAAA4Az9PwAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAH4RCICQO/4/bDv7P0Q++z8AAAAAAAAAAOwM/T8AAAAA
================= CORE DUMP END =================
E (2402) esp_core_dump: Skipped 1 tasks with bad TCB!
E (2407) esp_core_dump: Crashed task has been skipped!
I (2413) esp_core_dump: Core dump has been written to uart.
Rebooting...
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400807a0
D (62) bootloader_flash: mmu set block paddr=0x00000000 (was 0xffffffff)
I (40) boot: ESP-IDF v3.3-beta1-324-g2790d4a 2nd stage bootloader
I (40) boot: compile time 19:37:09
D (40) boot: Enabling RTCWDT(9000 ms)
I (53) boot: Enabling RNG early entropy source...
D (53) boot: magic e9
D (53) boot: segments 04
D (55) boot: spi_mode 02
D (57) boot: spi_speed 00
D (60) boot: spi_size 02
I (63) boot: SPI Speed      : 40MHz
I (67) boot: SPI Mode       : DIO
I (71) boot: SPI Flash Size : 4MB
D (75) bootloader_flash: mmu set paddr=00000000 count=1 size=c00 src_addr=8000 src_addr_aligned=0
D (84) boot: mapped partition table 0x8000 at 0x3f408000
D (89) flash_parts: partition table verified, 4 entries
I (94) boot: Partition Table:
I (98) boot: ## Label            Usage          Type ST Offset   Length
D (105) boot: load partition table entry 0x3f408000
D (110) boot: type=1 subtype=2
I (113) boot:  0 nvs              WiFi data        01 02 00009000 00006000
D (121) boot: load partition table entry 0x3f408020
D (126) boot: type=1 subtype=1
I (129) boot:  1 phy_init         RF data          01 01 0000f000 00001000
D (137) boot: load partition table entry 0x3f408040
D (142) boot: type=0 subtype=0
I (145) boot:  2 factory          factory app      00 00 00010000 00100000
I (152) boot: End of partition table
D (157) boot: Trying partition index -1 offs 0x10000 size 0x100000
D (163) esp_image: reading image header @ 0x10000
D (168) bootloader_flash: mmu set block paddr=0x00010000 (was 0xffffffff)
D (174) esp_image: image header: 0xe9 0x06 0x02 0x01 40081218
I (180) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x1cd80 (118144) map
D (189) bootloader_flash: mmu set paddr=00010000 count=2 size=1cd80 src_addr=10020 src_addr_aligned=10000
D (240) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff)
I (240) esp_image: segment 1: paddr=0x0002cda8 vaddr=0x3ffb0000 size=0x031e8 ( 12776) load
D (245) bootloader_flash: mmu set paddr=00020000 count=1 size=31e8 src_addr=2cda8 src_addr_aligned=20000
D (259) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff)
I (261) esp_image: segment 2: paddr=0x0002ff98 vaddr=0x40080000 size=0x00078 (   120) load
D (270) bootloader_flash: mmu set paddr=00020000 count=2 size=78 src_addr=2ff98 src_addr_aligned=20000
D (280) bootloader_flash: mmu set block paddr=0x00030000 (was 0xffffffff)
I (286) esp_image: segment 3: paddr=0x00030018 vaddr=0x400d0018 size=0x6b454 (439380) map
D (295) bootloader_flash: mmu set paddr=00030000 count=7 size=6b454 src_addr=30018 src_addr_aligned=30000
D (459) bootloader_flash: mmu set block paddr=0x00090000 (was 0xffffffff)
I (459) esp_image: segment 4: paddr=0x0009b474 vaddr=0x40080078 size=0x00388 (   904) load
D (463) bootloader_flash: mmu set paddr=00090000 count=1 size=388 src_addr=9b474 src_addr_aligned=90000
D (473) bootloader_flash: mmu set block paddr=0x00090000 (was 0xffffffff)
I (480) esp_image: segment 5: paddr=0x0009b804 vaddr=0x40080400 size=0x12674 ( 75380) load
D (489) bootloader_flash: mmu set paddr=00090000 count=2 size=12674 src_addr=9b804 src_addr_aligned=90000
D (530) bootloader_flash: mmu set block paddr=0x000a0000 (was 0xffffffff)
D (530) esp_image: Calculated hash: 97de951fd0471d655e356638f626a26ce3aa73e00461abaa24eb022c0e3ebf31
D (534) bootloader_flash: mmu set paddr=000a0000 count=1 size=20 src_addr=ade80 src_addr_aligned=a0000
D (544) bootloader_flash: mmu set paddr=000a0000 count=1 size=20 src_addr=ade80 src_addr_aligned=a0000
I (564) boot: Loaded app from partition at offset 0x10000
I (564) boot: Disabling RNG early entropy source...
D (565) boot: Mapping segment 0 as DROM
D (569) boot: Mapping segment 3 as IROM
D (573) boot: calling set_cache_and_start_app
D (577) boot: configure drom and irom and start
D (582) boot: start: 0x40081218
I (585) cpu_start: Pro cpu up.
I (589) cpu_start: Application information:
I (594) cpu_start: Project name:     ESP_ADS_WLAN
I (599) cpu_start: App version:      1
I (603) cpu_start: Compile time:     19:37:08
I (608) cpu_start: Compile date:     Feb 26 2019
I (614) cpu_start: ESP-IDF:          v3.3-beta1-324-g2790d4a
I (620) cpu_start: Starting app cpu, entry point is 0x400811c4
I (599) cpu_start: App cpu up.
I (631) heap_init: Initializing. RAM available for dynamic allocation:
I (637) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (644) heap_init: At 3FFD0928 len 0000F6D8 (61 KiB): DRAM
I (650) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (656) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (662) heap_init: At 40092A74 len 0000D58C (53 KiB): IRAM
I (669) cpu_start: Pro cpu start user code
I (16) esp_core_dump: Init core dump to UART
E (16) esp_core_dump: No core dump partition found!
I (17) cpu_start: Starting scheduler on PRO CPU.
I (105) wifi: wifi driver task: 3ffd7d18, prio:23, stack:3584, core=0
I (105) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (155) wifi: Init static rx buffer num: 10
I (285) phy: phy_version: 4100, 6fa5e27, Jan 25 2019, 17:02:06, 1, 0
I (285) wifi: mode : sta (30:ae:a4:bc:0f:cc)
I (285) tcp_perf:: wifi_init_sta finished.
I (295) tcp_perf:: connect to ap SSID:ESP32 2.4 password:Cao5566thU
I (415) wifi: new:<1,0>, old:<1,0>, ap:<255,255>, sta:<1,0>, prof:1
I (1395) wifi: state: init -> auth (b0)
I (1395) wifi: state: auth -> assoc (0)
I (1415) wifi: state: assoc -> run (10)
A2      : 0x00000000  A3      : 0x3ffb0db0  A4      : 0xffffffff  A5      : 0x3ffd2cd0
A6      : 0x00000000  A7      : 0x3ffd18e4  A8      : 0x00003424  A9      : 0x3ffd401c
A10     : 0x0000000a  A11     : 0x3ffd2db0  A12     : 0x8008fca0  A13     : 0x3ffd2db0
A14     : 0x00000000  A15     : 0x00000000  SAR     : 0x0000001b  EXCCAUSE: 0x0000001c
Backtrace: 0x40084cf9:0x3ffb0d60 0x40084e8c:0x3ffb0d90 0x400d2f71:0x3ffb0db0 0x400d30b2:0x3ffb0e00 0x400d3179:0x3ffb0e30 0x4008257d:0x3ffb0e50 0x4013a377:0x3ffd2d70 0x400d2747:0x3ffd2d90 0x40090c9d:0x3ffd2db0 0x4008fc9d:0x3ffd2dd0
0x4013a377: esp_pm_impl_waiti at /home/khoi/esp/esp-idf/components/esp32/pm_esp32.c:487
0x400d2747: esp_vApplicationIdleHook at /home/khoi/esp/esp-idf/components/esp32/freertos_hooks.c:86
0x40090c9d: prvIdleTask at /home/khoi/esp/esp-idf/components/freertos/tasks.c:5093
I (1479) esp_core_dump: Press Enter to print core dump to UART...
I (1485) esp_core_dump: Print core dump to uart...
KBwAAAEAAAAJAAAAZAEAAA==
DBT9PxDe/T883/0/
EN79P9De/T+lpaWldDz7P3Q8+z8MFP0/bDz7PxQAAAClpaWlpaWlpQwU/T8AAAAA
BQAAAEDP/T90Y3BfY29ubgBA/T+lpaUA////fzzf/T8AAAAAIAoGAAUAAAACAAAA
oPwIgHDe/T8MMEA/AAAAAFDe/T8w3v0/DAAAAAAAAAAAAAAANC0NQAAAAACbBQAA
DDBAPyMFBgAAAAAAAAAAABgwQD8fAAAAAQAAAAUAAAAAAAAAsN79PzQtDUAAAAAA
AAAAAAAAAAAAAAAAAAAAAEAR/D8AAAAAAAAAAAAAAAAjAAYADBT9PwAAAAAAAAAA
AAAAANDe/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAADc3v0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAA
xDP9PxAy/T+8M/0/
GCMIQHqjE0AwBQYASicNgNAy/T8AAAAAAQAAgAAAAAABAAAAAwAAACMABgASJg2A
oDL9PwAAAAAjBgYAIAYGAAEAAAAgBgYA8EH9PwAAAAAHJg2AgDL9PwAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAACAGBgABAAAAIAYGAPBB/T+gDAmA8DL9PwgAAAABAAAA
mFP9P5BR/T+QU/0/
kFH9PzBT/T+PAAAA/Dv7P/w7+z+YU/0/9Dv7PwcAAADsSP0/7Ej9P5hT/T/kSP0/
EgAAAJRJ/T90aVQAAAAAAAAAAAAAAAAA////f5BT/T8AAAAAIQAGABIAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAABU/T8=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oBH9P/AP/T+YEf0/
8A/9PzAR/T94Don8CGb9P2z++j+gEf0/hDv7PwEAAAB0Df0/dA39P6AR/T9sDf0/
GCMIQP36CEAwCwYAiyEIgLAQ/T9IDf0/AAAAAJAN/T8AAAAAAQAAAAAAAAD9+giA
kBD9PwEAAAD8Pfs/AD77PwoAAAAAAIAAHAD0PwAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAEAAAABAAAAIAsGACMABgCg/AiA8BD9PwEAAAC8NQhA
AAAAAA4AAAAAAIAAHAD0P//////wEP0/AQAAALw1CEAE/vo/AAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAABgSCICAff4/KgAAACoAAAAAAAAAAAAAADwR/T8AAAAA
AGb9PyBk/T/4Zf0/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UPn6P5D6+j81xZ6UIH39Pwhm/T/8+vo/hDv7PwMAAAB86vo/fOr6P/z6+j906vo/
GCMIQP36CEAwDQYAmx8NgBD6+j9Q6vo/AAAAAJjq+j8AAAAAAQAAAAAAAAD9+giA
AAAAAIYAAAADAAAAIw4GAP////9Q+vo/AAAAAAAAAACY6vo/AAAAAFDq+j8AAAAA
GH39PzB7/T8Qff0/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E (2365) esp_core_dump: Skipped 1 tasks with bad TCB!
E (2370) esp_core_dump: Crashed task has been skipped!
I (2376) esp_core_dump: Core dump has been written to uart.
Rebooting...
Could you help me undestand why the esp32 crashes and reboot? It has no problem as long as I don't have any SPI command function inside the interrupt.
Would it be better to place the SPI command in a task instead? I need to use SPI commands to cycle through the MUX of the ADC chip at the rate of 100 Hz.
Re: Polling SPI Inside Timer Interrupt
Postby Sprite » Wed Feb 27, 2019 3:56 am
Don't do any stuff that's not specifically designed for ISR use in an ISR. (Specifically, anything that can block will crash as you've seen.) The right way is to have a task block on a semaphore or something and then do the SPI transaction, with the timer interrupt giving that semaphore. Alternatively, look into the esp_timer infrastructure, which already handles all that logic for you.
e2738729
Postby e2738729 » Wed Feb 27, 2019 3:36 pm
Thank you for your reply. So in a nutshell the following is the structure of the SPI call based on your suggestion:
1. We create a timer interrupt to take care of the timing
2. The interrupt will trigger xemaphoreGiveFromISR and hand over a task that runs SPI
3. The task will keep checking if(xSemaphoreTake(xSemaphore, portMAX_DELAY) == pdTRUE) and will execute the spi code when this if returns TRUE.
4. SPI performs polling to send and receive commands.
esp_timer set of APIs provide such facility. Internally, esp_timer uses a 32-bit hardware timer (FRC1, “legacy” timer). esp_timer provides one-shot and periodic timers, microsecond time resolution, and 64-bit range.
Side question: so esp_timer is essentially an easy-to-setup timer interrupt? Is there any difference between this and timer_config_t structure
Postby Sprite » Thu Feb 28, 2019 2:00 am
Your steps are correct, although 'The task will keep checking if(xSemaphoreTake' is not exactly right wording: the xSemaphoreTake will tell the scheduler just not to schedule the task until the semaphore is given, so you don't lose any cpu cycles to it.
The esp_timer API is easier to use (and easier to share between tasks) because internally it has the timer, 'semaphore' logic (actually a queue, if memory serves, but the idea is the same) and the task (which calls your callback) already built-in.
e2738729
Postby e2738729 » Fri Mar 01, 2019 3:14 am
Thanks for your suggestions. I had my code working now. I am planning to publish my code on github for ESP32 data collection with ADS1256 ADC chip from TI and send the data to the PC over WIFI.
Users browsing this forum: Google [Bot] and 2 guests
