Hello World example on Eclipse
frax84
Postby frax84 » Wed Jan 11, 2017 5:17 pm
i'm trying to import in Eclipse the Hello World example. After a bit of work i have been able to solve the errors on the include. By the way, i have still an error on:
The error is: "Problem description: Symbol 'CONFIG_FREERTOS_HZ' could not be resolved".
I'm still quite a noob of Eclipse IDE and esp-idf. What am i missing?
Thank you for the patience,
frax
kolban
Re: Hello World example on Eclipse
Postby kolban » Wed Jan 11, 2017 5:24 pm
To resolve that issue, add a
#include "sdkconfig.h"
at the start of your C source program. When you run "make menuconfig" to configure the environment for your application, that generates a set of configuration properties. During compilation, a "header file" is generated which contains C header definitions for the current configuration settings. The "sdkconfig.h" is the generated file name which includes those definitions.
frax84
Postby frax84 » Thu Jan 12, 2017 8:06 am
Thank you. Actually i'm not able to solve the problem but i suppose that's because i still have tu run a makeconfig and so the constant inside sdkconfig.h still have not a value. I'm going to read your book to increase my background before asking something else. Thank you
frax84
Postby frax84 » Thu Jan 12, 2017 11:20 am
Ok, i have been able to figure out how it works and i have been able to solve errors, build and flash on my esp32devkit. Thank you for the help :)
Users browsing this forum: Bytespider and 5 guests
