Auto provisioning using X.509 certificate using esp idf by direct method
Aji Gopal
Postby Aji Gopal » Mon Mar 11, 2019 8:11 am
Hi
we need to connect certain esp32 devices to our azsure IOT hub using x.509 certificate through Direct method.Should we get some sample codes or some supporting documents for the same.
jitin17
Re: Auto provisioning using X.509 certificate using esp idf by direct method
Postby jitin17 » Mon Mar 11, 2019 8:59 am
Hey, Please find Azure Device provisioning example on ESP32 here: https://github.com/espressif/esp-azure/ ... _ll_sample
To create x509 leaf certificates for devices follow this link: https://github.com/Azure/azure-iot-sdk- ... verview.md
Aji Gopal
Postby Aji Gopal » Mon Mar 11, 2019 1:34 pm
Thanks for your replay Jitin
We already refer the above-mentioned code but it works with a hardcoded device id. But am looking for DPS through direct method using x.509 certificate
Users browsing this forum: Baidu [Spider], ChatGPT-User and 1 guest
