Using ethernet as independent interface with ethernet to wifi bridge
bhakti
Postby bhakti » Tue Mar 19, 2019 11:52 am
In ethernet and wifi bridge condition, Can we use ethernet as independent interface as well?
I tried it in this code https://github.com/espressif/esp-iot-so ... s/eth2wifi by assigning static ip address to ethernet but either it is working in bridge mode or as independent interface using static ip.
Board : ESP32-EVB(olimex)
Development environment : msys32
Thank you in advance.
Thanks and Best regards,
Bhakti Deshpande.
