ESP32 separate antennas for BT and WIFI
chrisso
Postby chrisso » Mon Jan 16, 2017 9:22 pm
Hi All
Is it possible to have the BT and the WIFI go through separate antennas, for example, the BT using a PCB antenna and the Wifi to a SMA connector?
Chris
WiFive
Re: ESP32 separate antennas for BT and WIFI
Postby WiFive » Tue Jan 17, 2017 1:18 am
You could use an external rf switch like pycom boards do and have separate WiFi or Bluetooth modes not simultaneous operation.
Postby Sprite » Tue Jan 17, 2017 1:43 am
Well, WiFi and BT actually even use the same power amp and LNA internally (and share parts of the PHY as well, if memory serves) so theoretically the only way to do it is to have an external antenna switch, software-actuated when the chip switches protocols. But if I may ask: Why would you? Both are 2.4GHz protocols, both can use the same antenna just fine.
WiFive
Postby WiFive » Tue Jan 17, 2017 2:49 am
Why would you?
The only reason I can think of is the desire to localize or reduce interference on Bluetooth signals but have larger gain on wifi.
chrisso
Postby chrisso » Tue Jan 17, 2017 9:45 pm
I need one set of signal to go through a directional antenna.
Users browsing this forum: Barkrowler, ChatGPT-User and 5 guests
