SPI very slow
jollytopper
SPI very slow
Postby jollytopper » Mon Mar 25, 2019 2:28 am
I'm making consecutive calls to one device using polling transactions. I have acquired the bus in initialization. My transactions are relatively short and usually come in chunks of 10 (10 polling transactions).
I find that the speed is still not satisfactory. How can I improve this?
jollytopper
Re: SPI very slow
Postby jollytopper » Mon Mar 25, 2019 3:18 am
Specifically, by logging a time value I'm reading that each polling transaction takes around 3 ms. Should it not be much quicker? <100 us?
michael
Re: SPI very slow
Postby michael » Mon Mar 25, 2019 11:20 am
Hi jollytopper,
What's your clock speed?
Can you provide a piece of simple code for us to test it? From our internal test, one-byte transaction should only take 8us (at 10MHz).
jollytopper
Re: SPI very slow
Postby jollytopper » Thu May 30, 2019 2:45 am
I have found that the problem was I was outputting many ESP_LOG statements over UART, thus causing delay.
jollytopper
Re: SPI very slow
Postby jollytopper » Thu May 30, 2019 2:49 am
Ritesh
Contact:
Re: SPI very slow
Postby Ritesh » Sat Jun 01, 2019 10:55 am
So, After reducing logs dis you get improvement into SPI Speed?
Regards,
Ritesh Prajapati
jollytopper
Re: SPI very slow
Postby jollytopper » Mon Jun 03, 2019 1:56 am
Yes. Speed improved significantly after removing log statements.
Ritesh
Contact:
Re: SPI very slow
Postby Ritesh » Mon Jun 03, 2019 8:24 am
Great. Thanks for update regarding same.
Regards,
Ritesh Prajapati
Users browsing this forum: Bytespider, Google [Bot] and 8 guests
