Cmake with esp-mdf components
jesrix
Postby jesrix » Tue Apr 02, 2019 6:12 am
Hi there,
I work at a project where we have been using the Cmake and idf.py to for building with esp-idf, now we would like to use the esp-mdf. Is this possible with CMake, I can't find any documentation on the website.
Thanks,
jesrix
Re: Cmake with esp-mdf components
Postby jesrix » Tue Apr 02, 2019 7:38 am
I might add that I tried to make CmakeLists.txt files in all the MDF components manually.
.../esp-mdf/components/mcommon/CMakeLists.txt example:
set(COMPONENT_ADD_INCLUDEDIRS include)
set(COMPONENT_SRCS ./mdf_event_loop.c ./mdf_err_to_name.c ./mdf_info_store.c ./mdf_mem.c)
register_component()
And in the CMakeLists.txt in the project root
# The following lines of boilerplate have to be in your project's
# CMakeLists in this exact order for cmake to work correctly
cmake_minimum_required(VERSION 3.5)
set(CMAKE_EXPORT_COMPILE_COMMANDS 1)
set(MDF_VER command bash -c "cd $ENV{MDF_PATH} && git describe --always --tags --dirty")
#CPPFLAGS := -D MDF_VER=\"$(MDF_VER)\"
set(EXTRA_COMPONENT_DIRS $ENV{MDF_PATH}/components $ENV{MDF_PATH}/components/third_party)
#set(EXTRA_COMPONENT_DIRS ${EXTRA_COMPONENT_DIRS} )
message(STATUS "EXTRA_COMPONENT_DIRS: ${EXTRA_COMPONENT_DIRS}")
set(CMAKE_SYSROOT $ENV{IDF_PATH}/../xtensa-esp32-elf/xtensa-esp32-elf)
include_directories(
    $ENV{IDF_PATH}/../xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0
    $ENV{IDF_PATH}/../xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/xtensa-esp32-elf
    $ENV{IDF_PATH}/../xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/backward
    $ENV{IDF_PATH}/../xtensa-esp32-elf/lib/gcc/xtensa-esp32-elf/5.2.0/include
    $ENV{IDF_PATH}/../xtensa-esp32-elf/lib/gcc/xtensa-esp32-elf/5.2.0/include-fixed
project(cpp-mesh)
idf.py build fails with:
/home/jri/work/doms-wireless/projects/cpp-mesh/components/cpp-classes/Mesh.cpp:10:19: fatal error: mwifi.h: No such file or directory
ESP_@In逍遥子
Postby ESP_@In逍遥子 » Tue Apr 02, 2019 8:14 am
esp-mdf will support CMake as soon as possible.
If you hava some problem about CMake,you can find solution in Build System
I think you can refer to Preset Component Variables to set COMPONENT_REQUIRES variables.
