ESP32 + TFT not working - Screen Blank - Help!
whateverfast
Postby whateverfast » Fri Nov 04, 2022 5:19 am
I am trying to do this project: https://electropeak.com/learn/interfaci ... ith-esp32/
I have an ESP32S and a TFT SP1 2.8. I installed the TFT_eSPI libraries (using arduino ide) and edit the USER_SETUP file with the appropriate PINS and versions (I believe). However, I tried different configurations but I was unable to turn on the TFT. I know that the TFT is working because I have used it with another board.
In the USER_SETUP tried with different drivers: ILI9341_DRIVER and ILI9341_2_DRIVER and the result is the same. Also different PINS.
I also run with the differenr boards types: DO IT ESP32 DEVKIT V1, and other ones that also compile.
Can you please help :) Thank you
The pins are the following in the USER_SETUP file
#define TFT_MISO 19
#define TFT_MOSI 23
#define TFT_SCLK 18
#define TFT_CS 15 // Chip select control pin
#define TFT_DC 4 // Data Command control pin
#define TFT_RST 2 // Reset pin (could connect to RST pin)
The arduino code is the following:
#include <TFT_eSPI.h> // Hardware-specific library
#include <SPI.h>
TFT_eSPI tft = TFT_eSPI();       // Invoke custom library
void setup(void) {
  tft.init();
  tft.setRotation(0);
  Serial.begin(57600); // For debug
  tft.fillScreen(TFT_WHITE);
  Serial.println("Setup Done");
  Serial.println(TFT_MISO);
  Serial.println(TFT_MOSI);
  Serial.println(TFT_SCLK);
  Serial.println(TFT_CS);
  Serial.println(TFT_DC);
  Serial.println(TFT_RST);
  Serial.println(TFT_WIDTH);
  Serial.println(TFT_HEIGHT);
  #ifdef ILI9341_DRIVER
  Serial.println("ILI9341_DRIVER");
  #endif
  #ifdef ILI9341_2_DRIVER
  Serial.println("ILI9341_2_DRIVER");
  #endif
void loop() {
   tft.fillScreen(TFT_GREEN);
   delay(250);
   tft.fillScreen(TFT_BLACK);
   delay(250);
   delay(250);
   tft.fillScreen(TFT_RED);
   delay(250);
User_Setup.h
(16.76 KiB) Downloaded 323 times
vritzka
Re: ESP32 + TFT not working - Screen Blank - Help!
Postby vritzka » Sat Nov 05, 2022 1:15 pm
Does at least the background light turn on?
whateverfast
Postby whateverfast » Sun Nov 06, 2022 2:26 am
The background light flickers when I press the reset button. I have also tried with a different library and still no success. I double-checked the pins but had no success. Any ideas?
#include <Arduino_GFX_Library.h>
#define TFT_SCK    18
#define TFT_MOSI   23
#define TFT_MISO   19
#define TFT_CS     15
#define TFT_DC     21
#define TFT_RESET  17
void setup(void)
  Serial.begin(115200);
  Serial.print("MOSI: ");
  Serial.println(MOSI);
  Serial.print("MISO: ");
  Serial.println(MISO);
  Serial.print("SCK: ");
  Serial.println(SCK);
  Serial.print("SS: ");
  Serial.println(SS);
  Arduino_ESP32SPI bus = Arduino_ESP32SPI(TFT_DC, TFT_CS, TFT_SCK, TFT_MOSI, TFT_MISO);
  Arduino_ILI9341 display = Arduino_ILI9341(&bus, TFT_RESET);
  display.begin();
  display.fillScreen(WHITE);
  display.setCursor(20, 20);
  display.setTextSize(2);
  display.setTextColor(BLUE);
  display.print("Hello world");
void loop() {
vritzka
Postby vritzka » Mon Nov 07, 2022 2:31 am
The screen backlight should glow up as soon as you connect 3.3 V and ground.
Since its an LED, you need to connect it through a resistor (100 OHM would work).
It seems there is no resistor now. So maybe the high current draw makes the ESP32 turn off and thats why it doesn't work.
Users browsing this forum: Bytespider, meta-externalagent and 3 guests
