I found the driver for the JL1101 ethernet here https://github.com/dtlzp/relay_dev_demo ... ts/esp_eth. It is for the ESP32 IDF environment, how can this be made as an Arduino library so it can be used in the Arduino IDE?
JL1101 Etheret PHY
Re: JL1101 Etheret PHY
This will be possible if you add this driver to the Arduino via the Library Builder.
In sum, the ESP-IDF used on Arduino ESP32 core should be recompiled in order to add this new driver. Using it as an Arduino library will not be possible in this case.
Users browsing this forum: Qwantbot and 3 guests
