Hi all,
do you know how to flash the ESP8685-WROOM-03 without using testpad IO9?
JTAG signals are disabled and is not possible to program using ESP-PROG.
Stevasway
ESP8685-WROOM-03 flashing/programming
Re: ESP8685-WROOM-03 flashing/programming
You could try to use the built-in USB-serial-JTAG converter.
I have developed a clip-on device for flashing this chip, which can connect to a standard usb-serial device. It includes a push button for boot mode.
If you're interested I can sell you one for $20, let me know.
santerilindfors
Aria James
You can try using the UART bootloader method by connecting the ESP8685-WROOM-03 to a USB-to-UART adapter.
Marcoantonio
My solution was to use an old ESP32 module as a USB serial programmer and an 8-pin DIP clip on the edge of the board. For IO9, you can solder a wire and connect it directly to the programmer's IO0, or momentarily touch a test probe with your hand during the programming phase in your preferred IDE.
Marco
Marco
- IMG_20250917_151937.jpg (1.74 MiB) Viewed 1080 times
- IMG_20250917_152026.jpg (1.47 MiB) Viewed 1080 times
- edge connector.png (13.01 KiB) Viewed 1080 times
That's actually quite similar to SOICbite if you want something that stays in place.My solution was to use an old ESP32 module as a USB serial programmer and an 8-pin DIP clip on the edge of the board.
Marcoantonio
Cool, I didn't know it. Actually, there's so much stuff on the internet that it's practically impossible that someone hasn't had the same idea several times before. It's a shame the manufacturer of this module didn't place IO9 testpad in a location with easy access for soldering.
Marco
Marco
Users browsing this forum: Bing [Bot], Qwantbot and 1 guest
