ESP8685­-WROOM­-03 flashing/programming
stevasway
Postby stevasway » Thu Mar 09, 2023 4:22 pm
Hi all,
do you know how to flash the ESP8685­-WROOM­-03 without using testpad IO9?
JTAG signals are disabled and is not possible to program using ESP-PROG.
Stevasway
Re: ESP8685­-WROOM­-03 flashing/programming
Postby Sprite » Fri Mar 10, 2023 12:44 am
You could try to use the built-in USB-serial-JTAG converter.
grizzly
Postby grizzly » Thu Jul 27, 2023 7:40 pm
I have developed a clip-on device for flashing this chip, which can connect to a standard usb-serial device. It includes a push button for boot mode.
If you're interested I can sell you one for $20, let me know.
santerilindfors
Postby santerilindfors » Tue Apr 08, 2025 6:48 pm
I am interested of buying one.
Aria James
Postby Aria James » Tue Apr 15, 2025 6:50 pm
You can try using the UART bootloader method by connecting the ESP8685-WROOM-03 to a USB-to-UART adapter.
Marcoantonio
Postby Marcoantonio » Wed Sep 17, 2025 6:40 pm
My solution was to use an old ESP32 module as a USB serial programmer and an 8-pin DIP clip on the edge of the board. For IO9, you can solder a wire and connect it directly to the programmer's IO0, or momentarily touch a test probe with your hand during the programming phase in your preferred IDE.
Marco
edge connector.png (13.01 KiB) Viewed 1079 times
Postby Sprite » Thu Sep 18, 2025 1:42 pm
That's actually quite similar to SOICbite if you want something that stays in place.
Marcoantonio
Postby Marcoantonio » Thu Sep 18, 2025 5:23 pm
Cool, I didn't know it. Actually, there's so much stuff on the internet that it's practically impossible that someone hasn't had the same idea several times before. It's a shame the manufacturer of this module didn't place IO9 testpad in a location with easy access for soldering.
Marco
Users browsing this forum: Bing [Bot], Qwantbot and 1 guest
