I am trying to build and install esp-rainmaker-ios with Xcode. I reviewed the settings, and Bundle ID. But After building, Xcode display the following message, without any additional information.
"Unable to install ESP RainMaker"
"Please check your project settings and ensure that a valid product has been built."
Any idea what could be the issue?
Sam
https://github.com/espressif/esp-rainmaker-ios
Issue with esp-rainmaker-ios: "Unable to install ESP RainMaker"
vikas.chandra
- Espressif staff
Re: Issue with esp-rainmaker-ios: "Unable to install ESP RainMaker"
Can you please click on Details button and send us the screenshot for it?
Thanks for asking, here is the Details:
Unable to install "ESP RainMaker"
Domain: com.apple.dt.MobileDeviceErrorDomain
Code: -402653081
Recovery Suggestion: Please check your project settings and ensure that a valid product has been built.
User Info: {
DVTErrorCreationDateKey = "2023-08-30 21:02:52 +0000";
IDERunOperationFailingWorker = IDEInstalliPhoneLauncher;
There was an internal API error.
Code: -402653081
User Info: {
DVTRadarComponentKey = 261622;
MobileDeviceErrorCode = "(0xE8000067)";
"com.apple.dtdevicekit.stacktrace" = (
0 DTDeviceKitBase 0x000000010be90b1c DTDKCreateNSErrorFromAMDErrorCode + 300
1 DTDeviceKitBase 0x000000010bec5000 __90-[DTDKMobileDeviceToken installApplicationBundleAtPath:withOptions:andError:withCallback:]_block_invoke + 136
2 DVTFoundation 0x000000010193f480 DVTInvokeWithStrongOwnership + 76
3 DTDeviceKitBase 0x000000010bec4d7c -[DTDKMobileDeviceToken installApplicationBundleAtPath:withOptions:andError:withCallback:] + 1208
4 IDEiOSSupportCore 0x000000010bd7bc00 __118-[DVTiOSDevice(DVTiPhoneApplicationInstallation) processAppInstallSet:appUninstallSet:installOptions:completionBlock:]_block_invoke.147 + 2340
5 DVTFoundation 0x0000000101a49de0 __DVT_CALLING_CLIENT_BLOCK__ + 16
6 DVTFoundation 0x0000000101a4a84c __DVTDispatchAsync_block_invoke + 152
7 libdispatch.dylib 0x000000018c09a874 _dispatch_call_block_and_release + 32
8 libdispatch.dylib 0x000000018c09c400 _dispatch_client_callout + 20
9 libdispatch.dylib 0x000000018c0a3a88 _dispatch_lane_serial_drain + 668
10 libdispatch.dylib 0x000000018c0a45f8 _dispatch_lane_invoke + 384
11 libdispatch.dylib 0x000000018c0af244 _dispatch_workloop_worker_thread + 648
12 libsystem_pthread.dylib 0x000000018c248074 _pthread_wqthread + 288
13 libsystem_pthread.dylib 0x000000018c246d94 start_wqthread + 8
Analytics Event: com.apple.dt.IDERunOperationWorkerFinished : {
"device_model" = "iPhone14,5";
"device_osBuild" = "16.6 (20G75)";
"device_platform" = "com.apple.platform.iphoneos";
"launchSession_schemeCommand" = Run;
"launchSession_state" = 1;
"launchSession_targetArch" = arm64;
"operation_duration_ms" = 2040;
"operation_errorCode" = "-402653081";
"operation_errorDomain" = "com.apple.dt.MobileDeviceErrorDomain";
"operation_errorWorker" = IDEInstalliPhoneLauncher;
"operation_name" = IDEiPhoneRunOperationWorkerGroup;
"param_consoleMode" = 0;
"param_debugger_attachToExtensions" = 0;
"param_debugger_attachToXPC" = 1;
"param_debugger_type" = 5;
"param_destination_isProxy" = 0;
"param_destination_platform" = "com.apple.platform.iphoneos";
"param_diag_MainThreadChecker_stopOnIssue" = 0;
"param_diag_MallocStackLogging_enableDuringAttach" = 0;
"param_diag_MallocStackLogging_enableForXPC" = 1;
"param_diag_allowLocationSimulation" = 1;
"param_diag_checker_tpc_enable" = 1;
"param_diag_gpu_frameCapture_enable" = 0;
"param_diag_gpu_shaderValidation_enable" = 0;
"param_diag_gpu_validation_enable" = 0;
"param_diag_memoryGraphOnResourceException" = 0;
"param_diag_queueDebugging_enable" = 1;
"param_diag_runtimeProfile_generate" = 0;
"param_diag_sanitizer_asan_enable" = 0;
"param_diag_sanitizer_tsan_enable" = 0;
"param_diag_sanitizer_tsan_stopOnIssue" = 0;
"param_diag_sanitizer_ubsan_stopOnIssue" = 0;
"param_diag_showNonLocalizedStrings" = 0;
"param_diag_viewDebugging_enabled" = 1;
"param_diag_viewDebugging_insertDylibOnLaunch" = 1;
"param_install_style" = 0;
"param_launcher_UID" = 2;
"param_launcher_allowDeviceSensorReplayData" = 0;
"param_launcher_kind" = 0;
"param_launcher_style" = 0;
"param_launcher_substyle" = 0;
"param_runnable_appExtensionHostRunMode" = 0;
"param_runnable_productType" = "com.apple.product-type.application";
"param_testing_launchedForTesting" = 0;
"param_testing_suppressSimulatorApp" = 0;
"param_testing_usingCLI" = 0;
"sdk_canonicalName" = "iphoneos16.4";
"sdk_osVersion" = "16.4";
"sdk_variant" = iphoneos;
System Information
macOS Version 13.3.1 (Build 22E261)
Xcode 14.3.1 (21815) (Build 14E300c)
Timestamp: 2023-08-30T14:02:52-07:00
