Issue with esp-rainmaker-ios: "Unable to install ESP RainMaker"
samledev
Postby samledev » Tue Aug 29, 2023 5:37 pm
I am trying to build and install esp-rainmaker-ios with Xcode. I reviewed the settings, and Bundle ID. But After building, Xcode display the following message, without any additional information.
"Please check your project settings and ensure that a valid product has been built."
Screenshot 2023-08-29 at 10.35.57 AM.png (25.56 KiB) Viewed 6790 times
Any idea what could be the issue?
Sam
https://github.com/espressif/esp-rainmaker-ios
vikas.chandra
Re: Issue with esp-rainmaker-ios: "Unable to install ESP RainMaker"
Postby vikas.chandra » Wed Aug 30, 2023 4:53 am
Can you please click on Details button and send us the screenshot for it?
samledev
Postby samledev » Wed Aug 30, 2023 9:06 pm
Thanks for asking, here is the Details:
Unable to install "ESP RainMaker"
Domain: com.apple.dt.MobileDeviceErrorDomain
Code: -402653081
Recovery Suggestion: Please check your project settings and ensure that a valid product has been built.
User Info: {
    DVTErrorCreationDateKey = "2023-08-30 21:02:52 +0000";
    IDERunOperationFailingWorker = IDEInstalliPhoneLauncher;
There was an internal API error.
Code: -402653081
User Info: {
    DVTRadarComponentKey = 261622;
    MobileDeviceErrorCode = "(0xE8000067)";
    "com.apple.dtdevicekit.stacktrace" = (
	0   DTDeviceKitBase                     0x000000010be90b1c DTDKCreateNSErrorFromAMDErrorCode + 300
	1   DTDeviceKitBase                     0x000000010bec5000 __90-[DTDKMobileDeviceToken installApplicationBundleAtPath:withOptions:andError:withCallback:]_block_invoke + 136
	2   DVTFoundation                       0x000000010193f480 DVTInvokeWithStrongOwnership + 76
	3   DTDeviceKitBase                     0x000000010bec4d7c -[DTDKMobileDeviceToken installApplicationBundleAtPath:withOptions:andError:withCallback:] + 1208
	4   IDEiOSSupportCore                   0x000000010bd7bc00 __118-[DVTiOSDevice(DVTiPhoneApplicationInstallation) processAppInstallSet:appUninstallSet:installOptions:completionBlock:]_block_invoke.147 + 2340
	5   DVTFoundation                       0x0000000101a49de0 __DVT_CALLING_CLIENT_BLOCK__ + 16
	6   DVTFoundation                       0x0000000101a4a84c __DVTDispatchAsync_block_invoke + 152
	7   libdispatch.dylib                   0x000000018c09a874 _dispatch_call_block_and_release + 32
	8   libdispatch.dylib                   0x000000018c09c400 _dispatch_client_callout + 20
	9   libdispatch.dylib                   0x000000018c0a3a88 _dispatch_lane_serial_drain + 668
	10  libdispatch.dylib                   0x000000018c0a45f8 _dispatch_lane_invoke + 384
	11  libdispatch.dylib                   0x000000018c0af244 _dispatch_workloop_worker_thread + 648
	12  libsystem_pthread.dylib             0x000000018c248074 _pthread_wqthread + 288
	13  libsystem_pthread.dylib             0x000000018c246d94 start_wqthread + 8
Analytics Event: com.apple.dt.IDERunOperationWorkerFinished : {
    "device_model" = "iPhone14,5";
    "device_osBuild" = "16.6 (20G75)";
    "device_platform" = "com.apple.platform.iphoneos";
    "launchSession_schemeCommand" = Run;
    "launchSession_state" = 1;
    "launchSession_targetArch" = arm64;
    "operation_duration_ms" = 2040;
    "operation_errorCode" = "-402653081";
    "operation_errorDomain" = "com.apple.dt.MobileDeviceErrorDomain";
    "operation_errorWorker" = IDEInstalliPhoneLauncher;
    "operation_name" = IDEiPhoneRunOperationWorkerGroup;
    "param_consoleMode" = 0;
    "param_debugger_attachToExtensions" = 0;
    "param_debugger_attachToXPC" = 1;
    "param_debugger_type" = 5;
    "param_destination_isProxy" = 0;
    "param_destination_platform" = "com.apple.platform.iphoneos";
    "param_diag_MainThreadChecker_stopOnIssue" = 0;
    "param_diag_MallocStackLogging_enableDuringAttach" = 0;
    "param_diag_MallocStackLogging_enableForXPC" = 1;
    "param_diag_allowLocationSimulation" = 1;
    "param_diag_checker_tpc_enable" = 1;
    "param_diag_gpu_frameCapture_enable" = 0;
    "param_diag_gpu_shaderValidation_enable" = 0;
    "param_diag_gpu_validation_enable" = 0;
    "param_diag_memoryGraphOnResourceException" = 0;
    "param_diag_queueDebugging_enable" = 1;
    "param_diag_runtimeProfile_generate" = 0;
    "param_diag_sanitizer_asan_enable" = 0;
    "param_diag_sanitizer_tsan_enable" = 0;
    "param_diag_sanitizer_tsan_stopOnIssue" = 0;
    "param_diag_sanitizer_ubsan_stopOnIssue" = 0;
    "param_diag_showNonLocalizedStrings" = 0;
    "param_diag_viewDebugging_enabled" = 1;
    "param_diag_viewDebugging_insertDylibOnLaunch" = 1;
    "param_install_style" = 0;
    "param_launcher_UID" = 2;
    "param_launcher_allowDeviceSensorReplayData" = 0;
    "param_launcher_kind" = 0;
    "param_launcher_style" = 0;
    "param_launcher_substyle" = 0;
    "param_runnable_appExtensionHostRunMode" = 0;
    "param_runnable_productType" = "com.apple.product-type.application";
    "param_testing_launchedForTesting" = 0;
    "param_testing_suppressSimulatorApp" = 0;
    "param_testing_usingCLI" = 0;
    "sdk_canonicalName" = "iphoneos16.4";
    "sdk_osVersion" = "16.4";
    "sdk_variant" = iphoneos;
System Information
macOS Version 13.3.1 (Build 22E261)
Xcode 14.3.1 (21815) (Build 14E300c)
Timestamp: 2023-08-30T14:02:52-07:00
