I'm using touchRead(T0) to reach the touch input, and have tried digitalWrite, analogWrite, and ledcWrite which all work without touchRead but fail when I add it back.
I have done a little bit of reading and the things that jump out are the following. If they are in fact issues, I haven't found a way around them.
1) Slot 1 of SDIO pins, which includes pins 14 and 15, is multiplexed with touch... though I don't really know how that could cause an issue
2) Touch0 is on an ADC2 pin, pins 14 and 15 are also on ADC2 pins... again, not sure why this would cause an issue though.
Code: Untitled.txt Select all
//#include <WiFi.h>
#include "driver/adc.h"
#define LEDwhite 14
#define LED1 15
#define LED2 16
#define LED3 17
#define LED4 18
byte brightness;
int state = 0;
// TESTING
// the number of the LED pin
const int ledPin1 = 15;
const int ledPin2 = 16; // 16 corresponds to GPIO16
const int ledPin3 = 17;
const int ledPin4 = 18;
// setting PWM properties
const int freq = 5000;
const int ledChannel = 0;
const int resolution = 8;
// the setup routine runs once when you press reset:
void setup() {
// initialize serial communication at 9600 bits per second:
Serial.begin(9600);
//Serial.begin(115200);
//adc_power_release(); // disable ADC
//pinMode(LEDwhite, OUTPUT);
//pinMode(LED1, OUTPUT);
//pinMode(LED2, OUTPUT);
ledcSetup(ledChannel, freq, resolution);
ledcAttachPin(ledPin1, ledChannel);
ledcAttachPin(ledPin2, ledChannel);
//ledcAttachPin(ledPin3, ledChannel);
//ledcAttachPin(ledPin4, ledChannel);
//pinMode(LED3, OUTPUT);
//pinMode(LED4, OUTPUT);
//digitalWrite(LEDwhite, LOW);
//digitalWrite(LED1, LOW);
//digitalWrite(LED2, LOW);
//digitalWrite(LED3, LOW);
//digitalWrite(LED4, LOW);
brightness = 100;
// the loop routine runs over and over again forever:
void loop() {
//Serial.print("\nDefault ESP32 MAC Address: ");
//Serial.println(WiFi.macAddress());
// Various Tests
capacativeTouchTest();
//blinkTest();
//printButtonStates();
void capacativeTouchTest() {
//void adc_power_on(void);
//delay(10);
Button1 = touchRead(T0); // get value of Touch 0 pin = GPIO 4... can swap with 24?
//void adc_power_off(void);
//delay(10);
if (Button1 < 30){
ledcWrite(ledChannel, 50);
Serial.println("ON");
delay(10);
//turnWhiteOn();
else {
ledcWrite(ledChannel, 0);
Serial.println("OFF");
void brightnessTest() {
delay(500); // delay in between reads for stability
if (brightness < 50) {
brightness = brightness + 20;
} else {
brightness = 0;
analogWrite(LEDwhite, brightness);
Serial.print("Brightness: ");
Serial.println(brightness);
void turnWhiteOn(){
analogWrite(LEDwhite, 50);
delay(50);
void blinkTest() {
delay(250);
turnWhiteOn();
delay(250);
analogWrite(LEDwhite, LOW);
analogWrite(LED1, 50);
delay(250);
analogWrite(LED1, LOW);
analogWrite(LED2, 50);
delay(250);
analogWrite(LED2, LOW);
analogWrite(LED3, 50);
delay(250);
analogWrite(LED3, LOW);
analogWrite(LED4, 50);
delay(250);
analogWrite(LED4, LOW);
delay(5000);
