GPIO pulse generated - inconsistent width
marsal64
Postby marsal64 » Thu Jun 20, 2024 11:44 am
using ESP32-S3 at 160MHz, I run once per some seconds the code:
gpio_set_level(GPIO_NUM_36, 1);
gpio_set_level(GPIO_NUM_36, 0);
My app runs WiFi, UART and two other lightweight FreeRTOS tasks.
I observe non-consistent width of the "pulse" I generate on GPIO_NUM_36 pin:
Typically: 6.6uS
Sometimes: 1.275uS
Rarely: 3.3625uS
Could please anybody explain what is happening here?
Thank you
ok-home
Contact:
Re: GPIO pulse generated - inconsistent width
Postby ok-home » Thu Jun 20, 2024 1:45 pm
Hi
bitbang on esp32 gives unpredictable results
- interrupts (wifi,freertos...)
- cache misses
as an example simple code
 gpio_set_level(GPIO_BLINK, 1);
 gpio_set_level(GPIO_BLINK, 0);
 GPIO.out_w1ts = mask;
 GPIO.out_w1tc = mask;
when code in flash memory and IRAM and the process of swapping cache from flash memory
MicroController
Postby MicroController » Thu Jun 20, 2024 2:11 pm
Likely: Caching, possibly: synchronization of the CPU with the APB and the GPIO peripheral.
You can look into Dedicated GPIO to improve the latter, and put code into IRAM to avoid cache issues.
Users browsing this forum: Bing [Bot], ChatGPT-User, Google [Bot] and 2 guests
