Very disappointed in the decision to use the C/C++ (LSP) editor
gtjoseph
Postby gtjoseph » Sat Aug 10, 2024 3:35 pm
I wish I'd have had the time to participate in the 3.0 beta but I simply didn't so here's my somewhat late feedback...
The LSP editor is a HUGE step backwards in terms of features.
  • Doesn't use the C/C++ Code Formatter
  • Doesn't even obey the tab size and type set in General/Editors
  • Only basic Save actions.
  • Missing context menu items like Declarations and References.
  • It's SLOW
  • No code folding for preprocessor #if/#endif
  • No coloring for code deactivated by preprocessor #if/#endif
  • The hovers are overly intrusive
  • The Outline doesn't include macros, doesn't allow grouping, doesn't allow hiding.
  • There are more but you get the idea.
The only thing wrong with the standard CDT C/C++ editor was that indexing was mostly broken but there were ways, albeit clunky and sometimes unreliable, to get it to work. We can't even do that now because you've disabled the ability to make it the default editor and it seems the indexer is now completely non-functional for esp-idf with the CDT editor. Why couldn't you have just fixed the indexer to work with the CDT editor???
kondalkolipaka
Re: Very disappointed in the decision to use the C/C++ (LSP) editor
Postby kondalkolipaka » Tue Aug 13, 2024 6:28 am
I have published a blog post on why we have moved to the LSP Editor and what it offers. Please check here
https://developer.espressif.com/blog/es ... p-support/
Many users have been reporting that the Eclipse CDT Editor/Indexer is unable to resolve headers and compilation units when working with ESP-IDF v5.0 and higher. This issue arises because the Eclipse CDT only supports the versions up to C++14. However, ESP-IDF v5.0 uses C++20 (with GCC 11.2) and ESP-IDF v5.2 uses C++23 (with GCC 13.1).
By adopting an LSP-based editor, Espressif-IDE v3.0.0 enables support for newer C/C++ standards required by more recent versions of ESP-IDF. Conversely, the old CDT C/C++ editor and its Indexer are not supported for ESP-IDF projects anymore. However, you can still use the CDT C/C++ editor for non-ESP-IDF projects as-is.
Improving the CDT Parser with the new language grammar is a huge task that requires dedicated resources. However, we feel this is not a productive task as the world is moving towards LSP-based editors; therefore, putting efforts there is not a viable option. Importantly, we need to constantly update the parser whenever there is new version support.
We will be addressing some of the limitations mentioned above in upcoming releases.
LSP based editor uses clang based formatter, please refer to this
https://developer.espressif.com/blog/es ... formatting
https://github.com/espressif/idf-eclips ... 2202018650
The LSP Editor is based on the standard editor. You can set the tab width, line spacing, etc., from Preferences > General > Editors > Text Editors.
Agreed.However, you should be able to use Ctrl+click or F3. If, for some reason, this is not working, please check here.
https://github.com/espressif/idf-eclips ... 2276935107
>It's SLOW
My observation is that the LSP indexer is faster compared old indexer. Please share your findings on this with details.
This is addresed on master branch, will be available in the next release 3.1.0.
Here is the master build if you want to try.
https://github.com/espressif/idf-eclips ... 1800310442
Please share more details for investigation.
Thank you for sharing your views and concerns. I’m sure we will turn this around in a couple of releases.
gtjoseph
Postby gtjoseph » Tue Aug 13, 2024 4:30 pm
OK, that's fair.
OK, also fair.
Using .clang-format is quite hard because you can't immediately see the result. You have to actually do a reformat. Having https://clang.llvm.org/docs/ClangFormat ... tions.html open in another window or tab helps but it's still not easy.
There's no format-as-you-type.
Some settings will also conflict with those in General -> Editors. Tab type (spaces or tabs) and Tab Width for instance. clang-format defaults to a TabWidth of 4 and "use spaces". If you set "use tabs" in General -> Editors, tabs will be used as you type but on a reformat, the tabs will be replaced with spaces. You have to set "UseTabs: Always" in .clang-format to make sure it stays tabs after a reformat.
See above.
For finding the declaration, yes. There's no equivalent for finding usages as far as I can tell.
>It's SLOW
It's the speed of the hovers that's seems slower.
I'll give it a shot today.
Unfortunately we can't easily paste images here but here's the hover for the max_cmdline_length member of the esp_console_config_t structure in the CDT...
size_t max_cmdline_length;  //!< length of command line buffer, in bytes
Here's the hover using the LSP editor...
field max_cmdline_length
Type: size_t (aka unsigned int)
// In (anonymous struct)
public: size_t max_cmdline_length
The CDT version is just one line and is all you need.
There also doesn't seem to be a way to control proposals. If I start typing "st" I really don't need to see a list pop up listing every function in the universe that starts with "st".
We'll see how it goes. I've reverted to 2.12.1 for now but also have the Espressif IDE 3.0.0 bundle installed so I can see them side-by-side.
gtjoseph
Postby gtjoseph » Tue Aug 13, 2024 10:24 pm
I installed the current master build and do see changes for preprocessor #id/#elif/#endif but they're not very useful right now.
Here's how it looks in the CDT editor...
It's really clear what's going on.
Here's how it looks in the LSP editor...
The green text is the same color as the comments and doesn't really make it obvious that that code is inactive and the #elif should be "active". I don't see any way to change the colors.
Of course, you still can't fold them either.
martins
Postby martins » Wed Aug 14, 2024 11:21 am
For the inactive code BLOCK highlight, I appreciate the effort, but yea, that really is not it. Could we just change the background color of whole inacive line(s) and leave everthing else the same?
gtjoseph
Postby gtjoseph » Thu Aug 15, 2024 1:38 pm
Yeah that would be a good way to do it for now.
gtjoseph
Postby gtjoseph » Fri Aug 16, 2024 10:17 pm
Here's another example of something completely useless and irritating...
A hover to tell me I'm hovering over a string literal???
I realize that this is a standard clangd thing but there's apparently no way to disable these and it's another example of why moving to an immature editor is disappointing.
martins
Postby martins » Thu Nov 28, 2024 8:38 am
There seems to be A LOT of work to do for the IDE to be where it used to be, probably depending not just on the Espressif side, but also in used editor and other tools, which will most likely take quite some time, if ever.
It turns out that VSCode with clangd extension does support inactive code block highlight in almost the same way as we were used to in CDT editor.
Hovers are bloated in same way, but its font and sizes are better optimized which makes it readable quite well and less intrusive.
Themes and colors should also be more configurable than in current Eclipse editor.
The main disadvantage currently is that clangd extension requires some manual configuration deepnding on chip target and IDF version.
kondalkolipaka
Postby kondalkolipaka » Mon Dec 02, 2024 8:20 am
Inactive code block is implemented with the v3.1.0, please see if that's helpful.
https://github.com/espressif/idf-eclips ... tag/v3.1.0
martins
Postby martins » Mon Dec 02, 2024 8:29 am
I tried the v3.1.0, but inactive code is still marked as comment instead of just background highlight of whole block while keeping original syntax highlight. Unless I missed some settings?
See https://github.com/clangd/vscode-clangd ... 1502199447 for reference.
