1. Using ESP-WROOM-32 kit as in attached mail. THis kit has Silabs CP2102 on it.
Kit is connected to PC via USB cable (attached pic)
2. A) in IDE, if i go to Help-> About ESpressif IDE, I can see "Version: 3.1.0, Build id: 20241007-0706"
B) In ESP-IDF manager -> version 5.3.2
C) OS - Windows 10 Pro
3. I am using Hello WOrld example, I cam see "Hello World" on terminal,
but when i start to debug, i got error either in pic2 or pic3
code is here: https://drive.google.com/file/d/176kuQf ... sp=sharing
4. GDB server timeout I set to 20000sec
5. One doubt I have is can we debug ESp-wroom-32 kit as in pic1 attahced over USB?
Or I am making some mistake
Issue going to debug mode - ESP-Wroom-32
- pic3.png (11.28 KiB) Viewed 3301 times
- pic.png (1.46 MiB) Viewed 3301 times
- pic2.png (16.47 KiB) Viewed 3301 times
Re: Issue going to debug mode - ESP-Wroom-32
You need to connect a debug probe to the jtag pins, see https://docs.espressif.com/projects/esp ... -jtag.html
Can you plz help to share the ESP32 debugger which can buy online & then connect to ESP-Wroom-32(as in attached image) for debug purpose
- pic.png (1.46 MiB) Viewed 2462 times
Look for an ESP-Prog board. For more detail also read through Espressif's JTAG debugging guide. The ESP-Prog uses an FT2232H USB bridge chip, so you can also use a simple breakout board with an FT2232H or FT232H chip. Other JTAG adapter options that can be used with OpenOCD: https://openocd.org/doc/html/Debug-Adap ... dware.html
So there is no way to debug an ESP32-WROOM* without using a separate JTAG device ? The on board USB interface allows for flashing only ?You need to connect a debug probe to the jtag pins, see https://docs.espressif.com/projects/esp ... -jtag.html
*But the ESP32-C3 WROOM appears to be debuggable with esp_usb_jtag according to "Other" in this: https://openocd.org/doc/html/Debug-Adap ... dware.html ?
Users browsing this forum: Baidu [Spider], Bing [Bot], meta-externalagent and 2 guests
