Compiling Error - ESP is resetting continuously
Postby mahmoodsaid » Wed Jan 08, 2025 7:22 pm
I am trying to compile a code from Arduino IDE to my ESP32 where I got the below error:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) flash read err, 1000 ets_main.c 371
I need help to solve this issue !!! :roll: :!:
I have tried changing the cable and changing the programming speed to 115200, but I still get the same error.
The error above kept sending from ESP32 continuously via the serial port.
Need an urgent support >>>>
Re: Compiling Error - ESP is resetting continuously
Postby Sprite » Wed Jan 08, 2025 11:42 pm
You'll need to tell us a lot more before we can help you. What hardware are you using, what are you flashing, how are you flashing?
chegewara
Postby chegewara » Thu Jan 09, 2025 12:39 am
Usually this eror means that flash is empty, no binary or bootloader flashed.
