[BLE][IDF v5.3.x/5.4.0] Unable to Keep Periodic Advertising Running After Stopping Extended Advertising
iamcalledusman
Postby iamcalledusman » Tue Jan 21, 2025 10:15 am
Code: Untitled.c Select all
Hello Espressif Team,
I am facing an issue with Extended Advertising and Periodic Advertising in ESP-IDF, specifically:
Stopping Extended Advertising Also Stops Periodic Advertising
According to the Bluetooth 5.0 spec, it should be possible to continue periodic advertising even after stopping extended advertising on the same handle. However, in my testing with ESP-IDF, once I call esp_ble_gap_ext_adv_stop(...), the periodic advertising also stops.
Large Extended Advertising Intervals Appear Clamped at ~40 s
When I set .interval_min and .interval_max to larger 24-bit values (e.g., 0x1FFFF for ~81 s), I still observe an actual advertising interval closer to 40 s. This suggests the controller might be falling back to the 16-bit legacy limit, even though I am using a non-legacy extended advertising property (NONCONN_NONSCANNABLE_UNDIRECTED).
My requirement is to have a short burst of extended advertising to establish periodic sync, and then either:
Stop extended advertising entirely while keeping periodic advertising on the same handle, or
Use a truly large extended advertising interval (e.g., ~81 s or more, up to the 24-bit limit of ~2.9 hours) to minimize power consumption.
However, neither approach seems possible in practice with the current ESP-IDF
Environment
Module or Chip: ESP32-C6
ESP-IDF Version: v5.3.2/v5.4.0(tried both)
Compiler: riscv32-esp-elf-gcc
Operating System: Windows
Power Supply: USB
Example code : https://github.com/espressif/esp-idf/tr ... riodic_adv
#define EXT_ADV_HANDLE 0
static esp_ble_gap_ext_adv_params_t ext_adv_params = {
.type = ESP_BLE_GAP_SET_EXT_ADV_PROP_NONCONN_NONSCANNABLE_UNDIRECTED,
.interval_min = 0x1FFFF, // aiming for ~81 s
.interval_max = 0x1FFFF,
.channel_map = ADV_CHNL_ALL,
.filter_policy = ADV_FILTER_ALLOW_SCAN_ANY_CON_ANY,
.primary_phy = ESP_BLE_GAP_PHY_1M, // Tried with CODED as well
.max_skip = 0,
.secondary_phy = ESP_BLE_GAP_PHY_2M, // // Tried with CODED as well
.sid = 0,
.scan_req_notif = false,
.own_addr_type = BLE_ADDR_TYPE_RANDOM,
.tx_power = EXT_ADV_TX_PWR_NO_PREFERENCE,
static esp_ble_gap_periodic_adv_params_t periodic_adv_params = {
.interval_min = 24000, // ~30 s
.interval_max = 24000,
.properties = 0,
LOG FILE :
I (23) boot: ESP-IDF v5.4 2nd stage bootloader
I (24) boot: compile time Jan 19 2025 01:50:29
I (24) boot: chip revision: v0.0
I (24) boot: efuse block revision: v0.1
I (27) boot.esp32c6: SPI Speed : 80MHz
I (31) boot.esp32c6: SPI Mode : DIO
I (34) boot.esp32c6: SPI Flash Size : 2MB
I (38) boot: Enabling RNG early entropy source...
I (43) boot: Partition Table:
I (45) boot: ## Label Usage Type ST Offset Length
I (52) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (58) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (65) boot: 2 factory factory app 00 00 00010000 00100000
I (71) boot: End of partition table
I (75) esp_image: segment 0: paddr=00010020 vaddr=420b0020 size=2452ch (148780) map
I (110) esp_image: segment 1: paddr=00034554 vaddr=40800000 size=03ac4h ( 15044) load
I (113) esp_image: segment 2: paddr=00038020 vaddr=42000020 size=ae23ch (713276) map
I (246) esp_image: segment 3: paddr=000e6264 vaddr=40803ac4 size=0ede4h ( 60900) load
I (259) esp_image: segment 4: paddr=000f5050 vaddr=408128b0 size=02718h ( 10008) load
I (266) boot: Loaded app from partition at offset 0x10000
I (267) boot: Disabling RNG early entropy source...
I (277) cpu_start: Unicore app
I (285) cpu_start: Pro cpu start user code
I (286) cpu_start: cpu freq: 160000000 Hz
I (286) app_init: Application information:
I (288) app_init: Project name: periodic_adv_demos
I (294) app_init: App version: 1
I (299) app_init: Compile time: Jan 19 2025 01:48:45
I (305) app_init: ELF file SHA256: 26082cade...
I (310) app_init: ESP-IDF: v5.4
I (314) efuse_init: Min chip rev: v0.0
I (319) efuse_init: Max chip rev: v0.99
I (324) efuse_init: Chip rev: v0.0
I (329) heap_init: Initializing. RAM available for dynamic allocation:
I (336) heap_init: At 408197E0 len 00062E30 (395 KiB): RAM
I (342) heap_init: At 4087C610 len 00002F54 (11 KiB): RAM
I (348) heap_init: At 50000000 len 00003FE8 (15 KiB): RTCRAM
I (356) spi_flash: detected chip: generic
I (359) spi_flash: flash io: dio
W (363) spi_flash: Detected size(8192k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (377) sleep_gpio: Configure to isolate all GPIO pins in sleep state
I (384) sleep_gpio: Enable automatic switching of GPIO sleep configuration
I (391) coexist: coex firmware version: 49a8cdc
I (405) coexist: coexist rom version 5b8dcfa
I (405) main_task: Started on CPU0
I (405) main_task: Calling app_main()
I (425) BLE_INIT: Using main XTAL as clock source
I (425) BLE_INIT: ble controller commit:[b623f7a]
I (425) BLE_INIT: Bluetooth MAC: 40:4c:ca:4a:a3:3a
I (425) phy_init: phy_version 320,348a293,Sep 3 2024,16:33:12
I (475) phy: libbtbb version: 04952fd, Sep 3 2024, 16:33:30
I (695) PERIODIC_ADV_DEMO: Extended advertising params set, status 0, instance 0
I (695) PERIODIC_ADV_DEMO: Extended advertising random address set, status 0, instance 0
I (695) PERIODIC_ADV_DEMO: Extended advertising data set, status 0, instance 0
I (705) PERIODIC_ADV_DEMO: Extended advertising start, status 0, instance numble 1
I (715) PERIODIC_ADV_DEMO: Periodic advertising params set, status 0, instance 0
I (725) PERIODIC_ADV_DEMO: Periodic advertising data set, status 0, instance 0
I (735) main_task: Returned from app_main()
Observed Behavior
esp_ble_gap_ext_adv_stop(1, &ext_adv[EXT_ADV_HANDLE]);
This also kills periodic advertising on the same handle. The logs confirm both advertisements stop.
Large Interval Clamped
If I do not stop extended advertising, I set .interval_min = 0x1FFFF (aiming for ~81 s). In practice, using a BLE sniffer or a scanning device, I see the device advertising at ~40 s intervals, indicating a fallback to the legacy 16-bit maximum.
Expected Behavior
According to the BLE Specification: We can keep periodic advertising running even if we stop sending extended advertising PDUs, or we can set an extended interval up to 0xFFFFFF (~2.9 hours) for truly extended advertising.
In either case, we would see either zero extended adv overhead (only periodic PDUs) or a very infrequent extended adv interval.
Question / Request
Is this a known limitation or bug in the ESP-IDF BLE controller stack?
Are there workarounds to achieve “periodic only” without extended PDUs or to set the interval larger than ~40 s?
Is there any plan to support stopping extended advertising while keeping periodic advertising active on the same handle, in line with the BLE spec?
Any guidance or solutions would be greatly appreciated.
Wireshark Logs
You can see that I set the interval of 0x1FFFF but getting PDU almost every 41 seconds, Tried with coded phy as well but still the same behavior.
Thank you!
Users browsing this forum: Applebot, Baidu [Spider], Bing [Bot], ChatGPT-User, DuckDuckGo [Bot], Qwantbot and 3 guests
