In VSCODE I select PSRAM enabled and also chosen MALLOC_CAP_SPIRAM so ps_malloc must be used.
psramInit() fails.
when I right click on the function name and select GOTO DEFINITION it shows me this function!
bool psramInit() {
return false;
a hard coded fail... when I look into it further up in the file a few lines it due to the fact that
neither conditions are met #if CONFIG_SPIRAM_SUPPORT || CONFIG_SPIRAM
when they are clearly selected SDK Config Editor, I click SAVE and clean build and compile and the same thing.
Anyone experience this?
PSRAM not working even after sdkconfig has it on!
themindfactory
- spi.png (40.65 KiB) Viewed 1911 times
Last edited by themindfactory on Thu Jan 30, 2025 8:15 pm, edited 1 time in total.
themindfactory
Re: PSRAM not working even after sdkconfig has it on!
Also to note:
And this is even after configuring SPIRAM enabled at boot.
Even though Serial.println(heap_caps_get_largest_free_block(MALLOC_CAP_SPIRAM)); reports 4M
on the first call to ps_malloc(x) it will return NULL!
Richard.
Richard.
MicroController
themindfactory
Yes, and same result.
Fact is the initPSRAM() is returning FALSE... so until it returns TRUE I think they will all not work
R.
R.
nopnop2002
- Contact:
For ESP32S3, you may need to specify the mode.
- psram-esp32s3.jpg (145.93 KiB) Viewed 1791 times
themindfactory
I am using VSCODE but the setting are almost the same
Users browsing this forum: Applebot, Bing [Bot], Bytespider, Qwantbot and 3 guests
