PSRAM not working even after sdkconfig has it on!
themindfactory
Postby themindfactory » Thu Jan 30, 2025 8:00 pm
In VSCODE I select PSRAM enabled and also chosen MALLOC_CAP_SPIRAM so ps_malloc must be used.
psramInit() fails.
when I right click on the function name and select GOTO DEFINITION it shows me this function!
bool psramInit() {
return false;
a hard coded fail... when I look into it further up in the file a few lines it due to the fact that
neither conditions are met #if CONFIG_SPIRAM_SUPPORT || CONFIG_SPIRAM
when they are clearly selected SDK Config Editor, I click SAVE and clean build and compile and the same thing.
Anyone experience this?
Last edited by themindfactory on Thu Jan 30, 2025 8:15 pm, edited 1 time in total.
themindfactory
Re: PSRAM not working even after sdkconfig has it on!
Postby themindfactory » Thu Jan 30, 2025 8:15 pm
Also to note:
And this is even after configuring SPIRAM enabled at boot.
Even though Serial.println(heap_caps_get_largest_free_block(MALLOC_CAP_SPIRAM)); reports 4M
on the first call to ps_malloc(x) it will return NULL!
Richard.
MicroController
Postby MicroController » Thu Jan 30, 2025 9:40 pm
Have you tried heap_caps_malloc(...)?
themindfactory
Postby themindfactory » Thu Jan 30, 2025 10:12 pm
Yes, and same result.
Fact is the initPSRAM() is returning FALSE... so until it returns TRUE I think they will all not work :-)
R.
nopnop2002
Contact:
Postby nopnop2002 » Thu Jan 30, 2025 11:37 pm
For ESP32S3, you may need to specify the mode.
themindfactory
Postby themindfactory » Fri Jan 31, 2025 12:31 am
I am using VSCODE but the setting are almost the same :-)
Users browsing this forum: Bing [Bot], Qwantbot and 3 guests
