***ERROR*** A stack overflow in task main has been detected.
smit.italiya
Re: ***ERROR*** A stack overflow in task main has been detected.
Postby smit.italiya » Sat Feb 15, 2025 9:37 am
#define configSTACK_DEPTH_TYPE uint32_t
it takes uint32_t ,so we can say that 256 bytes is enough for esp_logi also i tried with increasing the stack size by 1024 but got the same output. anything else did i wrong in the code?
Actually not. Espressif version freertos we are using is using uint8 in stack depth.
Small tip here:
- minimum stack size is 1500-2000
- with logs, printf, sprintf etc its safe to start with stack size 3500-4000
Thanks for your tip, I increased stack size by 2024 but after increasing the stack size i got another error related to watch dog,
**ERROR**
E (15317) task_wdt: Task watchdog got triggered. The following tasks/users did not reset the watchdog in time:
E (15317) task_wdt: - IDLE0 (CPU 0)
E (15317) task_wdt: Tasks currently running:
E (15317) task_wdt: CPU 0: main
E (15317) task_wdt: CPU 1: IDLE1
E (15317) task_wdt: Print
CPU 0 (current core) backtrace
Then i searched online and found solution that guy suggest to - Not Set The Watchdog of IDEAL task for both core 0 and 1 from menuconfig that it i did not got any error on Monitor window but this is the right way ? any effect on running FreeRTOS task ?
Bryght-Richard
Postby Bryght-Richard » Mon Feb 17, 2025 3:23 pm
while(1) {
ESP_LOGI(TAG, "While loop!!");
//nothing to do
^^^This main loop is the probably triggering the watchdog. It never suspends.
Users browsing this forum: Bing [Bot], PetalBot, Semrush [Bot] and 2 guests
