Error on building the Switch example from esp-rainmaker
rodrigopandini
Postby rodrigopandini » Sun Mar 23, 2025 11:29 am
Hi.
I'm getting the error bellow when I try to build the Switch example from esp-rainmaker.
Not sure if is wrong version or something else.
Can someone help me?
Code: Untitled.bsh Select all
/home/myuser/.espressif/tools/xtensa-esp-elf/esp-14.2.0_20241119/xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/14.2.0/../../../../xtensa-esp-elf/bin/ld: esp-idf/esp_wifi/libesp_wifi.a(esp_adapter.c.obj):(.data.g_wifi_osi_funcs+0x150): undefined reference to `__wrap_esp_log_write'
/home/myuser/.espressif/tools/xtensa-esp-elf/esp-14.2.0_20241119/xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/14.2.0/../../../../xtensa-esp-elf/bin/ld: esp-idf/esp_wifi/libesp_wifi.a(esp_adapter.c.obj):(.data.g_wifi_osi_funcs+0x154): undefined reference to `__wrap_esp_log_writev'
collect2: error: ld returned 1 exit status
* The terminal process "ninja" terminated with exit code: 1.
Not sure if this can help, but I'm attaching an image that show all information that Arduino IDE provide me about my esp32 device, when I successfully run a simple example for blink led.
Screenshot from 2025-03-23 07-25-43.png (60.46 KiB) Viewed 1059 times
Screenshot from 2025-03-23 07-14-49.png (13.22 KiB) Viewed 1059 times
Last edited by rodrigopandini on Mon Mar 24, 2025 9:19 am, edited 1 time in total.
ahsrabrifat
Re: Error on building the Switch example from esp-rainmaker
Postby ahsrabrifat » Sun Mar 23, 2025 5:48 pm
Check if your CMakeLists.txt includes the logging component:
idf_component_register(SRCS "main.c"
                       INCLUDE_DIRS "."
                       REQUIRES log)
