Need help overriding "_ulp_riscv_interrupt_handler"
derock
Postby derock » Fri Apr 25, 2025 9:57 pm
I would like to know the cause of a ULP wakeup. I read on the datasheet for the S3 that the wakeup reason is stored in the q1 register. Looking at the ESP-IDF source, it registers a weak function `_ulp_riscv_interrupt_handler` that gets called with the wakeup reason as it's first parameter:
/* This is the global interrupt handler for ULP RISC-V.
 * It is called from ulp_riscv_vectors.S
void __attribute__((weak)) _ulp_riscv_interrupt_handler(uint32_t q1)
    /* Call respective interrupt handlers based on the interrupt status in q1 */
    /* Internal Interrupts */
    if (q1 & ULP_RISCV_INTERNAL_INTERRUPT) {
        // TODO
    /* External/Peripheral interrupts */
    if (q1 & ULP_RISCV_PERIPHERAL_INTERRUPT) {
        /* RTC Peripheral interrupts */
        uint32_t cocpu_int_st = READ_PERI_REG(SENS_SAR_COCPU_INT_ST_REG);
        if (cocpu_int_st) {
            ulp_riscv_handle_rtc_periph_intr(cocpu_int_st);
        /* RTC IO interrupts */
        uint32_t rtcio_int_st = REG_GET_FIELD(RTC_GPIO_STATUS_REG, RTC_GPIO_STATUS_INT);
        if (rtcio_int_st) {
            ulp_riscv_handle_rtc_io_intr(rtcio_int_st);
        /* TODO: RTC I2C interrupt */
From: https://github.com/espressif/esp-idf/bl ... upt.c#L110
My goal is to differentiate between wakeups due to timer and wakeups due to RTC GPIO changes.
In my ULP main.c file, I've attempted to override the function:
 * This function overrides the weak default implementation.
 * It is called by the assembly vector code (ulp_riscv_vectors.S)
 * https://github.com/espressif/esp-idf/blob/465b159cd8771ffab6be70c7675ecf6705b62649/components/ulp/ulp_riscv/ulp_core/ulp_riscv_interrupt.c#L16
 * Default interrupt handler has "// TODO" for timer interrupts which we need.
void _ulp_riscv_interrupt_handler(uint32_t q1) {
  ulp_error_flags++; // This is just a random variable I have that I can read from main CPU
It seems, though, that my overriden `_ulp_riscv_interrupt_handler` never gets called. If I move my `ulp_error_flags++;` to the `void main()` of the ULP main.c, then I can read from the main CPU that the number increments as the timer fires and as GPIO changes.
What do I have to do to override the original `_ulp_riscv_interrupt_handler`? I've done a fullclean and rebuild.
