ESP32-C3 trying to output 40MHz on GPIO10
espmich
Postby espmich » Mon Jul 07, 2025 9:46 pm
In order to probe the crystal frequency without touching it, I want to create a periodic wave on GPIO10 to measure using my frequency counter. This is commonplace in other MCUs with a MCO (master clock output) function.
#include <stdio.h>
#include "freertos/task.h"
#include "driver/ledc.h"
#include "esp_err.h"
void app_main() {
    // Configure the LEDC timer
    ledc_timer_config_t timer_conf;
    timer_conf.speed_mode = LEDC_LOW_SPEED_MODE;
    timer_conf.duty_resolution = LEDC_TIMER_1_BIT;
    timer_conf.timer_num = LEDC_TIMER_0;
    timer_conf.freq_hz = 40000000;
    //timer_conf.clk_cfg = APB_CLK;
    timer_conf.clk_cfg = LEDC_USE_XTAL_CLK;
    timer_conf.deconfigure = false;
    ledc_timer_config(&timer_conf);
    // Configure the LEDC channel
    ledc_channel_config_t channel_conf;
    channel_conf.gpio_num = 10; // Pin 16 GPIO-10
    channel_conf.speed_mode = LEDC_LOW_SPEED_MODE;
    channel_conf.channel = LEDC_CHANNEL_0;
    channel_conf.intr_type = LEDC_INTR_DISABLE;
    channel_conf.timer_sel = LEDC_TIMER_0;
    channel_conf.duty = 0;
    channel_conf.hpoint = 0;
    ledc_channel_config(&channel_conf);
    // Start the output
    ledc_update_duty(LEDC_LOW_SPEED_MODE, LEDC_CHANNEL_0);
    // Keep the task running
    while (1) {
        vTaskDelay(pdMS_TO_TICKS(1000));
Unfortunately when I program the ESP32-C3 chip with the above code, it fails to ouput a periodic wave on GPIO10. I'm not sure what is wrong, want to take a look?
Re: ESP32-C3 trying to output 40MHz on GPIO10
Postby Sprite » Thu Jul 10, 2025 5:02 am
You cannot get a 40MHz signal from the LEDC if you use the XTAL clock. Does it also not work if you use the APB clock?
espmich
Postby espmich » Fri Jul 18, 2025 7:49 pm
Before seeing your reply I tried switching code to the:
esp-idf/examples/peripherals/ledc/ledc_basic
project. I was able to generate 4KHz signal but at 40KHz the MCU fails again, and of course 4MHz fails as you mentioned.
This project uses:
ledc_timer.clk_cfg = LEDC_AUTO_CLK
Actually all these clock optoins confuse me. I changed the above line to:
ledc_timer.clk_cfg = LEDC_USE_APB_CLK
...and will now try to test it again with a frequency counter. Please stay tuned.
espmich
Postby espmich » Fri Jul 18, 2025 8:09 pm
In case the LEDC peripheral is totally incapable of generating a clean 40MHz signal, what other options are there to do this?
espmich
Postby espmich » Fri Jul 18, 2025 9:18 pm
I tested the LEDC peripheral as described above, using the LEDC_USE_APB_CLK but it failed at about 9-10KHz.
I'm confused, can the ESP chips not output a stable high frequency signal?
espmich
Postby espmich » Mon Jul 21, 2025 4:04 pm
Any idea how to generate a 40 MHz signal, can a hardware timer be used or some configuration value in LEDC?
Postby Sprite » Tue Jul 22, 2025 2:37 am
That does not sound right. What frequency counter and what setup are you using?
espmich
Postby espmich » Thu Jul 24, 2025 12:51 pm
The frequency counter I'm using to measure the ESP32-C3 is the same one I use to measure all the STM32 MCUs successfully. It is an Philips PM-6672 with a standard (oscilloscope style) probe:
https://www.archive.org/details/manual_ ... OM_PHILIPS
This device indicates the frequency correctly on my ESP32-C3, whenever I set the MCU LEDC peripheral to output at 4KHz.
What I already did:
  • 1) Use Google search and copy the AI answer provided, real source code.
    2) Use the LEDC basic example in the ESP-IDF 5.42 development environment.
    3) Adjust #2 above to use Sprite TM's suggestion changing the clock to try all (AUTO, XTAL, APB) clocks.
Would you @Sprite please show example code here that is reasonably expected to work correctly? Please assume the GPIO10 (pin 16 on a ESP32-C3FH4 chip) as output. Thank you!
Postby Sprite » Fri Jul 25, 2025 1:01 am
- Using ESP-IDF v5.4.2
- Using an ESP32-C3-DevkitM-1 v1.0
- Example examples/peripherals/ledc/ledc_basic
- Modify main/ledc_basic_example_main.c as such:
#define LEDC_OUTPUT_IO          (10) // Define the output GPIO
#define LEDC_DUTY_RES           LEDC_TIMER_1_BIT // Set duty resolution to 1 bit
#define LEDC_FREQUENCY          (40000000) // Frequency in Hertz. Set frequency at 40MHz
- Probing GPIO10:
Given that I get a proper 40MHz, I'd imagine there may be something wrong with your setup. Do you have something else (a logic analyzer or an oscilloscope, for instance) that can verify your measurement?
espmich
Postby espmich » Sat Jul 26, 2025 5:15 pm
Thanks @Sprite and everything is working after your LEDC suggestion.
It appears my AI generated code set the duty cycle to 0 (should be 4096) and I had not modified the ESP-IDF LECD basic sample from LEDC_TIMER_13_BIT to LEDC_TIMER_1_BIT resolution. Nothing was working with those mistakes.
Users browsing this forum: Amazon [Bot] and 4 guests
