FreeRTOS time anomalie?
My program measures the exact time between two events (interrupts) with microsecond accuracy. Every 17.8 seconds the measurements are distorted by several hundred microseconds. Has anyone encountered such behavior of FreeRTOS?
MicroController
Re: FreeRTOS time anomalie?
At 240MHz, the 32 bit CPU cycle counter overflows every 17.89 seconds. Coincidence?
dmitrij999
What kind of timer for microseconds checking you use?
If it's the hardware timer, then it could be interrupts priorities: systick timer may have the highest interrupt priority.
What's the original purpose to account microseconds?
For flow counter I used PCNT
This is obvious. Common place
I use esp_timer_get_time() function.
Original purpose is soft PLL for incoming periodic sequence.
Can PCNT provide microsecond (~10us) accuracy?
MicroController
Do you need to match only the frequency or also the phase?
Phase (the exact time beetwen local and remote periodic events) is a fundamentally important and is the main goal of measurements
dmitrij999
That's the reasonI use esp_timer_get_time() function.
esp_timer is driven the software way within FreeRTOS, so due to some hardware spinlocks FreeRTOS scheduler may be locked.
I used PCNT for pulse counting.
For your purpose i'd advise you to check with hardware timer, I think it's the high-accuracy timer so it allows to account microseconds.
That's the reason.I use esp_timer_get_time() function.
You're right.
I found a simple intermediate solution:
using cpu_hal_get_cycle_count() function (paired with _set_) instead of esp_timer_get_time()
Thanks everyone!
UPD: hardware timer also works well
