FreeRTOS time anomalie?
enGaryN
Postby enGaryN » Sat Aug 02, 2025 11:05 pm
My program measures the exact time between two events (interrupts) with microsecond accuracy. Every 17.8 seconds the measurements are distorted by several hundred microseconds. Has anyone encountered such behavior of FreeRTOS?
MicroController
Re: FreeRTOS time anomalie?
Postby MicroController » Sun Aug 03, 2025 7:45 am
At 240MHz, the 32 bit CPU cycle counter overflows every 17.89 seconds. Coincidence?
dmitrij999
Postby dmitrij999 » Sun Aug 03, 2025 9:37 am
What kind of timer for microseconds checking you use?
If it's the hardware timer, then it could be interrupts priorities: systick timer may have the highest interrupt priority.
What's the original purpose to account microseconds?
For flow counter I used PCNT
enGaryN
Postby enGaryN » Sun Aug 03, 2025 1:10 pm
This is obvious. Common place
enGaryN
Postby enGaryN » Sun Aug 03, 2025 1:13 pm
I use esp_timer_get_time() function.
Original purpose is soft PLL for incoming periodic sequence.
Can PCNT provide microsecond (~10us) accuracy?
MicroController
Postby MicroController » Sun Aug 03, 2025 4:05 pm
Do you need to match only the frequency or also the phase?
enGaryN
Postby enGaryN » Sun Aug 03, 2025 4:15 pm
Phase (the exact time beetwen local and remote periodic events) is a fundamentally important and is the main goal of measurements
dmitrij999
Postby dmitrij999 » Sun Aug 03, 2025 5:51 pm
That's the reason
esp_timer is driven the software way within FreeRTOS, so due to some hardware spinlocks FreeRTOS scheduler may be locked.
I used PCNT for pulse counting.
For your purpose i'd advise you to check with hardware timer, I think it's the high-accuracy timer so it allows to account microseconds.
enGaryN
Postby enGaryN » Sun Aug 03, 2025 7:06 pm
That's the reason.
You're right.
I found a simple intermediate solution:
using cpu_hal_get_cycle_count() function (paired with _set_) instead of esp_timer_get_time()
Thanks everyone!
UPD: hardware timer also works well
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot], PerplexityBot, Semrush [Bot] and 7 guests
